Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
how to install the license
3 REPLIES 3
Ilarin75
258 Views, 3 Replies
Hi, I can't find a guide and all the links are broken...so complicated
I try to install the arnold license for houdini on linux
the output::
qt.network.ssl: QSslSocket: cannot resolve CRYPTO_num_locks
qt.network.ssl: QSslSocket: cannot resolve CRYPTO_set_id_callback
qt.network.ssl: QSslSocket: cannot resolve CRYPTO_set_locking_callback
qt.network.ssl: QSslSocket: cannot resolve ERR_free_strings
qt.network.ssl: QSslSocket: cannot resolve EVP_CIPHER_CTX_cleanup
qt.network.ssl: QSslSocket: cannot resolve EVP_CIPHER_CTX_init
qt.network.ssl: QSslSocket: cannot resolve sk_new_null
qt.network.ssl: QSslSocket: cannot resolve sk_push
Cannot register file downloader for https protocol: QSslSocket::supportsSsl() returns false
[474595] Warning: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1759, resource id: 14585268, major code: 40 (TranslateCoords), minor code: 0
[474600] Warning: Only RedHat 6 or above is supported!\n
[474998] Warning: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1870, resource id: 13219575, major code: 40 (TranslateCoords), minor code: 0
[475003] Warning: Only RedHat 6 or above is supported!\n
Segmentation fault
Tags (1)
Labels (1)
3 REPLIES 3
Stephen.Blair
in reply to: Ilarin75
What linux distro?
// Stephen Blair
// Arnold Renderer Support
Ilarin75
I'm on fedora 34
Stephen.Blair
Looks like an incompatible version of OpenSSL:
https://bugreports.qt.io/browse/QTBUG-95363?gerritReviewStatus=Open
If you cannot use a different distro, you'll have to submit a previous version request (previous version licenses use a different licensing system and won't have this problem, and can run the current version of Arnold).
See Q13 here:
https://knowledge.autodesk.com/support/arnold/learn-explore/caas/simplecontent/content/introducing-a...
// Stephen Blair
