Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
How do I put a foreground image in render view?
4 REPLIES 4
jstewartJ2BWZ
518 Views, 4 Replies
How do I put a foreground image in the render view? I want it to overlay my rendered geo.
I want it on a plane and unaffected by lights. I initially thought to use the utility/flat shader but there is no opacity.
Any tips?
Tags (1)
Labels (1)
4 REPLIES 4
lee_griggs
in reply to: jstewartJ2BWZ
Have you tried it with an opacity map on a card?
https://docs.arnoldrenderer.com/display/A5AFHUG/Geometry
Lee Griggs
Arnold rendering specialist
AUTODESK
Thanks for your answer. I have tried the opacity on the standard surface and that works but I'm left with the diffuse (which is all I want) but it's affected by the scene lighting. (which I don't want). Basically, I want this image as a foreground lighting reference with alpha as opposed to a backplate reference image. I think a flat shader like the utility works fine but has no opacity. Is there a way to make the standard shader flat or combine a utility shader with a opacity mask?
lee_griggs
Use emission_color instead.
Lee Griggs
AUTODESK
Great. That worked. Thanks
