Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
houdini16.5.268 for arnold2.20 version as long as arnold_skydome_light lights will be incorrect, as shown below, this is a software bug, or other problems.
9 REPLIES 9
Message 1 of 10
2867145495
421 Views, 9 Replies
Tags (1)
Labels (1)
9 REPLIES 9
Message 2 of 10
in reply to: 2867145495
Hi
working fine here!
Tested with exr and tx file
Message 3 of 10
2867145495
Hello, I tested, I do not know what is the problem here. As long as the map with arnold_skydome_light, it will be incorrect. Any other light is fine. It's okay to remove the texture. Will be able to render normally. Thank you.
Message 4 of 10
2867145495
Or not, can you send me the paper to see. You test the file, it should be able to send it to me, I test the test here.
Message 5 of 10
2867145495
Message 6 of 10
You have to manually convert you file to .tx format
from .exr or .hdr to .tx
maketx -u --oiio file.hdr
Message 7 of 10
2867145495
Now you have to use TX format and EXR format Well, there is no better converter recommended. thank you
Message 8 of 10
2867145495
Message 9 of 10
it's just a preference but you can use oiiotool.exe found in htoa-2.2.0_r9912855_houdini-16.5.268\scripts\bin
Message 10 of 10
2867145495
Thank you, really grateful
