Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Houdini Python3 version Support?
5 REPLIES 5
elon_wu
1551 Views, 5 Replies
Does the current HTOA support Houdini python3 version?
Houdini Console:
Error running pythonrc.py:
File "D:/Arnold/htoa/htoa-5.5.0.0_r5b05c8c_houdini-18.5.351/htoa-5.5.0.0_r5b05c8c_houdini-18.5.351/scripts/python/pythonrc.py", line 11
print '[htoa] HTOA environment variable already set to %s' % os.environ['HTOA']
SyntaxError: Missing parentheses in call to 'print'. Did you mean print('[htoa] HTOA environment variable already set to %s' % os.environ['HTOA'])?
Tags (3)
Labels (3)
5 REPLIES 5
Stephen.Blair
in reply to: elon_wu
No, you'll have to use the Python 2.7 version of Houdini with the current HtoA.
// Stephen Blair
// Arnold Renderer Support
chris_wood1
where would I change the above?
chris_wood1
in reply to: chris_wood1
HOUDINI_PYTHON_VERSION = python2.7
HOUDINI_PYTHON_BIN = C:\Python27
chris_wood1
I added those line to the Houdini env file and I still get the same result
Stephen.Blair
@ You have to download the Python 2.7 version of Houdini, and install that.
// Stephen Blair
