I have the log I don't see anything wrong, but I really don't know what I am looking at.
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x15d858d60, name="RE_WindowWindow") , parent: QWindow(0x0) , transient parent: QWindow(0x0)
00:00:00 785MB | log started Mon Nov 26 13:46:16 2018
00:00:00 785MB | Arnold 5.2.1.0 [7c7c9701] windows icc-17.0.2 oiio-1.7.17 osl-1.9.9 vdb-4.0.0 clm-1.0.3.513 rlm-12.4.2 2018/10/19 21:35:58
00:00:00 785MB | running on Puget-171184, pid=11016
00:00:00 785MB | 2 x Intel(R) Xeon(R) CPU E5-2697 v4 @ 2.30GHz (36 cores, 72 logical) with 65420MB
00:00:00 785MB | Nvidia driver version 416.81
00:00:00 785MB | GPU 0: GeForce GTX 1080 @ 1733MHz (compute 6.1) with 8192MB (5925MB available)
00:00:00 785MB | GPU 1: GeForce GTX 1080 @ 1733MHz (compute 6.1) with 8192MB (8079MB available)
00:00:00 785MB | GPU 2: GeForce GTX 1080 @ 1733MHz (compute 6.1) with 8192MB (8079MB available)
00:00:00 785MB | GPU 3: GeForce GTX 1080 @ 1733MHz (compute 6.1) with 8192MB (8079MB available)
00:00:00 785MB | Windows 8 Professional (version 6.2, build 9200)
00:00:00 785MB | soft limit for open files raised from 2048 to 2048
00:00:00 785MB |
00:00:00 785MB | loading plugins from C:/Users/Steven/htoa/htoa-3.2.0_r9e1313b_houdini-17.0.352/htoa-3.2.0_r9e1313b_houdini-17.0.352/arnold\plugins ...
00:00:00 785MB | loading plugins from C:/Users/Steven/htoa/htoa-3.2.0_r9e1313b_houdini-17.0.352/htoa-3.2.0_r9e1313b_houdini-17.0.352/arnold\drivers ...
00:00:00 785MB | loaded 6 plugins from 4 lib(s) in 0:00.02
00:00:00 785MB | [htoa.session] Session OpId: 15
00:00:00 785MB | [htoa.session] SOHO mode: generate
00:00:00 785MB | [metadata] loading metadata file: C:/Users/Steven/htoa/htoa-3.2.0_r9e1313b_houdini-17.0.352/htoa-3.2.0_r9e1313b_houdini-17.0.352/arnold/metadata/cameras.mtd
00:00:00 785MB | [metadata] loading metadata file: C:/Users/Steven/htoa/htoa-3.2.0_r9e1313b_houdini-17.0.352/htoa-3.2.0_r9e1313b_houdini-17.0.352/arnold/metadata/lights.mtd
00:00:00 785MB | [metadata] loading metadata file: C:/Users/Steven/htoa/htoa-3.2.0_r9e1313b_houdini-17.0.352/htoa-3.2.0_r9e1313b_houdini-17.0.352/arnold/metadata/operators.mtd
00:00:00 785MB | [metadata] loading metadata file: C:/Users/Steven/htoa/htoa-3.2.0_r9e1313b_houdini-17.0.352/htoa-3.2.0_r9e1313b_houdini-17.0.352/arnold/metadata/options.mtd
00:00:00 785MB | [metadata] loading metadata file: C:/Users/Steven/htoa/htoa-3.2.0_r9e1313b_houdini-17.0.352/htoa-3.2.0_r9e1313b_houdini-17.0.352/arnold/metadata/shaders.mtd
00:00:00 785MB | [metadata] loading metadata file: C:/Users/Steven/htoa/htoa-3.2.0_r9e1313b_houdini-17.0.352/htoa-3.2.0_r9e1313b_houdini-17.0.352/arnold/metadata/shapes.mtd
00:00:00 785MB | [htoa.session] Camera: /obj/cam1
00:00:00 790MB | [htoa.object.rop] Generating ROP /out/arnold1
00:00:00 790MB | [htoa.object.camera] Generating camera /obj/cam1
00:00:00 790MB | [htoa.object.geometry] Generating /obj/geo1
00:00:00 790MB | [class std::map<struct AtNode *,class std::vector<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,class std::allocator<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > > >,struct std::less<struct AtNode *>,class std::allocator<struct std::pair<struct AtNode * const,class std::vector<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,class std::allocator<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > > > > > > __cdecl htoa::pygeo::Object::build] translate as: geo
00:00:00 790MB | [htoa.object.light] Generating skydome light /obj/arnold_light1
00:00:00 790MB | [htoa.material] Generating shader /shop/arnold_vopnet1/standard_surface1
00:00:00 790MB | [htoa.texture] Converted 0 textures in 0:00:00 (0 skipped, 0 errors)
00:00:00 791MB | [htoa.session] SOP cache cleared. 22 nodes unloaded.
00:00:00 791MB | [ass] writing scene to c:\users\steven\appdata\local\temp\houdini_temp\htoa_Steven\11016_df3e80a5-c91d-4462-815d-788991ce8e2f.ass (mask=0xFFFF) ...
00:00:00 791MB | [ass] wrote 2671 bytes, 9 nodes in 0:00.00
00:00:00 791MB |
00:00:00 791MB | releasing resources
00:00:00 789MB | Arnold shutdown
