Houdini Packages?
Houdini Packages?
Houdini Packages?
Anyone can advice how I can use Houdini Packages for Arnold?
I have tried many different approaches without success. One example below:
Arnold works normally in the env file, but in packages ROP properties are empty, and it doesn't render (traceback errors). Although the shelf is there.
{"path" : "C:/Users/billk/htoa/htoa-5.2.0_r0292f07_houdini-18.0.416/htoa-5.2.0_r0292f07_houdini-${HOUDINI_VERSION}/scripts/bin",
env" : [
"HOUDINI_PATH" : "C:/Users/billk/htoa/htoa-5.2.0_r0292f07_houdini-18.0.416/htoa-5.2.0_r0292f07_houdini-${HOUDINI_VERSION}"
"PATH" : { method" : "prepend",
"value" : ["C:/Users/billk/htoa/htoa-5.2.0_r0292f07_houdini-18.0.416/htoa-5.2.0_r0292f07_houdini-${HOUDINI_VERSION}/scripts/bin"]
Thanks!
Stephen.Blair
Check https://answers.arnoldrenderer.com/questions/20802/how-do-i-install-arnold-using-the-new-packages-sy...
I tried to fix your formatting. I didn't change anything except whitespace.
why path and HOUDINI_PATH ?
// Stephen Blair
// Arnold Renderer Support
Slava_91
Try this
"enable": true,
"env": [
"HTOA_DIR": "C:/htoa/5.2"
"HOUDINI_DSO_ERROR": "2"
"HOUDINI_PATH": "$HTOA_DIR"
"PATH": "$HTOA_DIR/scripts/bin"
