Message 1 of 15
Hello all. I'm aware Arnold has the Python 3.7 version, but does it support the Houdini Py3.9 version?
Thanks!
Thanks!
The default download is Python 3.9
No "py" extension? That means the download is an HtoA that matches the default Python version of Houdini
To me, it would seem reasonable that on that downloads page, there would be an * that states Py3.9 is now the default, and the install isn't labeled as such. IMO.
It's working properly now, thanks.
Thanks!
Hello,, i install the standar Arnold version but this can't run in HOudini ... can I help me please?/... thanks for the help friends
@cm403270 wrote:
... this can't run in HOudini...
Can you tell us more about the problem? Does HtoA not load, and you don't see anything in Houdini about Arnold?
Or does it load and give you errors when you try to use it? If so, what errors?
Hi thanks for you answer... I install arnold on the default route... and I cant see anything in houdini about arnold..
Most likely, houdini.env is the problem.
The HtoA installer updates the houdini.env in your User folder. For example:
But Houdini uses the houdini.env from the One Drive folder. For example:
So, you can copy the HtoA settings from the houdini.env file from the User folder to the One Drive folder.
@cm403270 wrote:
Umm. I don't Know dude... I don't have one drive account on my computer... 😮
One Drive is included with Windows 11.
Let's see the details from Help > About Houdini > Show Details ?
I have windows 10 dude
This the info
Houdini FX Version 19.5.493
Operating System: Microsoft Windows 10 Pro x64
Number of Cores: 16
Physical Memory: 31.95 GB
Number of Screens: 2
Screen 0: 2560 x 1440 at 0,0
Work Area 0: 2560 x 1390 at 0,0
Screen 0 DPI: 123.5
Screen 1: 1920 x 1080 at 2560,0
Work Area 1: 1920 x 1020 at 2560,0
Screen 1 DPI: 141.0
Build platform: windows-x86_64-cl19.29
Python Version: 3.9
Qt Version: 5.15.2
USD Version: 22.05
USD git URL: https://github.com/sideeffects/USD.git
USD git Revision: 4a81c47f6ff02d8f0f8f6e50543ac3b349be3245
UI Scale: 1.250
OpenGL Vendor: NVIDIA Corporation
OpenGL Renderer: NVIDIA GeForce GTX 1650 SUPER/PCIe/SSE2
OpenGL Version: 4.6.0 NVIDIA 472.47
OpenGL Shading Language: 4.60 NVIDIA
Detected: NVidia Consumer
4096 MB
472.47.0.0
Supported Extensions not in OpenGL 3.3 (Version):
EXT_extensions_string
GL_ARB_base_instance (4.2)
GL_ARB_bindless_texture
GL_ARB_buffer_storage (4.4)
GL_ARB_clear_buffer (4.3)
GL_ARB_compatibility
GL_ARB_compute_shader (4.3)
GL_ARB_copy_texture (4.3)
GL_ARB_debug_output
GL_ARB_draw_indirect (4.0)
GL_ARB_gpu_shader5 (4.0)
GL_ARB_gpu_shader_fp64 (4.0)
GL_ARB_multi_bind (4.4)
GL_ARB_program_interface_query (4.3)
GL_ARB_robustness
GL_ARB_sample_shading (4.0)
GL_ARB_separate_shader_objects (4.1)
GL_ARB_shader_atomic_counters (4.2)
GL_ARB_shader_image_load_store (4.2)
GL_ARB_shader_storage_buffer_object (4.3)
GL_ARB_shading_language_packing (4.2)
GL_ARB_tessellation_shader (4.0)
GL_ARB_texture_buffer_object_rgb32 (4.0)
GL_ARB_texture_buffer_range (4.3)
GL_ARB_texture_cube_map_array (4.0)
GL_ARB_texture_filter_anisotropic (4.6)
GL_ARB_transform_feedback3 (4.0)
GL_ARB_vertex_attrib_64bit (4.1)
GL_EXT_abgr
GL_EXT_blend_minmax
GL_EXT_direct_state_access
GL_KHR_debug (4.3)
GL_NVX_gpu_memory_info
GL_NV_depth_buffer_float
GL_NV_gpu_shader5
WGL_EXT_swap_control
Unsupported OpenGL Extensions used by Houdini:
GL_ATI_meminfo
OpenGL Limits:
ELEMENTS_VERTICES 1048576
ELEMENTS_INDICES 1048576
VERTEX_UNITS 32
TESS_CONTROL_TEXTURE_IMAGE_UNITS 32
TESS_EVALUATION_TEXTURE_IMAGE_UNITS 32
GEOMETRY_UNITS 32
FRAGMENT_IMAGE_UNITS 32
COMBINED_UNITS 192
TEXTURE_SIZE 32768
3D_TEXTURE_SIZE 16384
CUBE_MAP_TEXTURE_SIZE 32768
RECTANGLE_TEXTURE_SIZE 32768
TEXTURE_ARRAY_LAYERS 2048
MAX_COLOR_TEXTURE_SAMPLES 32
MAX_DEPTH_TEXTURE_SAMPLES 32
FBO_ATTACHMENTS 8
DRAW_BUFFERS 8
VIEWPORT_DIMS 32768x32768
VERTEX_UNIFORMS 4096
FRAGMENT_UNIFORMS 4096
VERTEX_ATTRIBS 16
VERTEX_OUTPUT_COMPONENTS 128
MAX_CLIP_DISTANCES 8
PATCH_VERTICES 32
TESS_GEN_LEVEL 64
TESS_PATCH_COMPONENTS 120
TESS_CONTROL_OUTPUT_COMPONENTS 128
TESS_CONTROL_TOTAL_OUTPUT_COMPONENTS 4216
TESS_EVALUATION_OUTPUT_COMPONENTS 128
GEOMETRY_UNIFORM_COMPONENTS 2048
GEOMETRY_INPUT_COMPONENTS 128
GEOMETRY_OUTPUT_COMPONENTS 128
GEOMETRY_TOTAL_OUTPUT_COMPONENTS 1024
GEOMETRY_OUTPUT_VERTICES 1024
UNIFORM_BLOCKS 84
UNIFORM_BLOCK_SIZE 65536
UNIFORM_BUFFER_BINDINGS 84
COMBINED_VERT_UNIFORM_BLOCKS 14
COMBINED_VERT_UNIFORM_COMPS 233472
TESS_CONTROL_UNIFORM_BLOCKS 14
TESS_CONTROL_UNIFORM_COMPONENTS 2048
TESS_EVALUATION_UNIFORM_BLOCKS 14
TESS_EVALUATION_UNIFORM_COMPONENTS 2048
COMBINED_GEO_UNIFORM_BLOCKS 14
COMBINED_GEO_UNIFORM_COMPS 231424
COMBINED_FRAG_UNIFORM_BLOCKS 14
COMBINED_FRAG_UNIFORM_COMPS 233472
MAX_FRAGMENT_STORAGE_BLOCKS 16
MAX_STORAGE_BLOCK_BINDINGS 96
TRANSFORM_FEEDBACK_INT_COMPS 128
TRANSFORM_FEEDBACK_SEP_COMPS 4
TRANSFORM_FEEDBACK_SEP_ATTRIBS 4
LINE_WIDTH_RANGE 0.5 - 10
LINE_WIDTH_GRANULARITY 0.125
POINT_SIZE_RANGE 1 - 189.875
POINT_SIZE_GRANULARITY 0.125
OpenCL Platform NVIDIA CUDA
Platform Vendor NVIDIA Corporation
Platform Version OpenCL 3.0 CUDA 11.4.158
OpenCL Device NVIDIA GeForce GTX 1650 SUPER
OpenCL Type GPU
Device Version OpenCL 3.0 CUDA
Frequency 1755 MHz
Compute Units 20
Device Address Bits 64
Global Memory 4096 MB
Max Allocation 1024 MB
Global Cache 640 KB
Max Constant Args 9
Max Constant Size 64 KB
Local Mem Size 48 KB
2D Image Support 32768x32768
3D Image Support 16384x16384x16384
Max On Device Queues 4
Pref. Device Queue Size 256 KB
Max Device Queue Size 256 KB
OpenCL Platform Extensions:
cl_khr_global_int32_base_atomics
cl_khr_global_int32_extended_atomics
cl_khr_local_int32_base_atomics
cl_khr_local_int32_extended_atomics
cl_khr_fp64
cl_khr_3d_image_writes
cl_khr_byte_addressable_store
cl_khr_icd
cl_khr_gl_sharing
cl_nv_compiler_options
cl_nv_device_attribute_query
cl_nv_pragma_unroll
cl_nv_d3d10_sharing
cl_khr_d3d10_sharing
cl_nv_d3d11_sharing
cl_nv_copy_opts
cl_nv_create_buffer
cl_khr_int64_base_atomics
cl_khr_int64_extended_atomics
cl_khr_device_uuid
cl_khr_pci_bus_info
OpenCL Device Extensions:
cl_khr_fp64
cl_khr_icd
cl_khr_gl_sharing
cl_nv_pragma_unroll
cl_nv_d3d10_sharing
cl_nv_d3d11_sharing
cl_nv_copy_opts
cl_nv_create_buffer
cl_khr_device_uuid
cl_khr_pci_bus_info
Loaded Packages:
C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/packages/apex.json
C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/packages/kinefx.json
C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/packages/package_dirs.json
Environment:
ACTIVETAKE Main
ALLUSERSPROFILE C:\ProgramData
APPDATA C:\Users\CHRISTIAN\AppData\Roaming
COMPUTERNAME DESKTOP-MJTB9EJ
ComSpec C:\Windows\system32\cmd.exe
CommonProgramFiles(x86) C:\Program Files (x86)\Common Files
CommonProgramFiles C:\Program Files\Common Files
CommonProgramW6432 C:\Program Files\Common Files
DriverData C:\Windows\System32\Drivers\DriverData
FPS_BROWSER_APP_PROFILE_STRING Internet Explorer
FPS_BROWSER_USER_PROFILE_STRING Default
H C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493
HB C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/bin
HFS C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493
HH C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/houdini
HHC C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/houdini/config
HHP C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/houdini/python3.9libs
HIP C:/Users/CHRISTIAN
HIPFILE C:/Users/CHRISTIAN/untitled.hip
HIPNAME untitled
HOME C:/Users/CHRISTIAN/Documents
HOMEDRIVE C:
HOMEPATH \Users\CHRISTIAN
HOUDINI_DESKTOP_DIR C:/Users/CHRISTIAN/Desktop
HOUDINI_MAJOR_RELEASE 19
HOUDINI_MINOR_RELEASE 5
HOUDINI_OS Windows
HOUDINI_PATH C:/Users/CHRISTIAN/htoa/htoa-6.2.4.1_r47de8f7_houdini-19.5.752/htoa-6.2.4.1_r47de8f7_houdini-19.5.493;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/packages/kinefx;&
HOUDINI_QT_PREFERRED_BINDING PySide2
HOUDINI_TEMP_DIR C:/Users/CHRIST~1/AppData/Local/Temp/houdini_temp
HOUDINI_USER_PREF_DIR C:/Users/CHRISTIAN/Documents/houdini19.5
HOUDINI_VERSION 19.5.493
HOUDINI_VIEWERHANDLE_PATH C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/packages/kinefx/viewer_handles;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/houdini/viewer_handles
HOUDINI_VIEWERSTATE_PATH C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/packages/kinefx/viewer_states;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/houdini/viewer_states
HT C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/toolkit
HTB C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/toolkit/bin
JOB C:/Users/CHRISTIAN
LOCALAPPDATA C:\Users\CHRISTIAN\AppData\Local
LOGONSERVER \\DESKTOP-MJTB9EJ
MATERIALX_SEARCH_PATH C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/houdini/materialx
NUMBER_OF_PROCESSORS 16
OS Windows_NT
OneDrive C:\Users\CHRISTIAN\OneDrive
PAI_MODEL_DIR C:\ProgramData\Topaz Labs LLC\Topaz Photo AI\models
PATH C:\PROGRA~1\SIDEEF~1\HOUDIN~1.493\python39\lib\site-packages-forced\PySide2;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/python39;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/bin;C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/toolkit/bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Users\CHRISTIAN\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\CHRISTIAN\AppData\Local\Programs\Python\Python37\;C:\Users\CHRISTIAN\AppData\Local\Microsoft\WindowsApps;;C:/Users/CHRISTIAN/htoa/htoa-6.2.4.1_r47de8f7_houdini-19.5.752/htoa-6.2.4.1_r47de8f7_houdini-19.5.493/scripts/bin
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
POSE C:/Users/CHRISTIAN/Documents/houdini19.5/poselib
PROCESSOR_ARCHITECTURE AMD64
PROCESSOR_IDENTIFIER AMD64 Family 23 Model 113 Stepping 0, AuthenticAMD
PROCESSOR_LEVEL 23
PROCESSOR_REVISION 7100
PSModulePath C:\Program Files\WindowsPowerShell\Modules;C:\Windows\system32\WindowsPowerShell\v1.0\Modules
PUBLIC C:\Users\Public
PXR_MTLX_PLUGIN_SEARCH_PATHS C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/houdini/materialx
PXR_MTLX_STDLIB_SEARCH_PATHS C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/houdini/materialx/libraries
PYTHONHOME C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/python39
PYTHONUNBUFFERED 1
ProgramData C:\ProgramData
QT_D3DCREATE_MULTITHREADED 1
QT_LOGGING_RULES qt.svg.warning=false
QT_QPA_FONTDIR C:/PROGRA~1/SIDEEF~1/HOUDIN~1.493/houdini/fonts
SESSIONNAME Console
SystemDrive C:
SystemRoot C:\Windows
TEMP C:\Users\CHRIST~1\AppData\Local\Temp
TMP C:\Users\CHRIST~1\AppData\Local\Temp
USER CHRISTIAN
USERDOMAIN DESKTOP-MJTB9EJ
USERDOMAIN_ROAMINGPROFILE DESKTOP-MJTB9EJ
USERNAME CHRISTIAN
USERPROFILE C:\Users\CHRISTIAN
windir C:\Windows
HtoA 6.2.4.1 requires Houdini 19.5.752, you'll have to upgrade Houdini...or use an older version of HtoA
No dude.. I tryed with the old version to arnold and the new houdini version and I can't install arnold
Almost all problems are because of either Houdini/HtoA versions mismatch, or incorrect environment set up.
The only way to check is to check the houdini.env (or pkg file, if that's what you use), and the info from Help > About Houdini > Show Details.
