Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Hota env file
1 REPLY 1
ali.mahdavi.fx
302 Views, 1 Reply
Hota env file
hi
i have arnold and houdini fx 17.5 on cnetos 7.5
the problem is that arnold does not run in Houdini. i should edit houdini env file but i don not know what is the problem
this is my env file
# Houdini Environment Settings
# The contents of this file are read into the environment
# at startup. They will override any existing entries in
# the environment.
# The syntax is one entry per line as follows:
# VAR = VALUE
# Values may be quoted
# VAR = "VALUE"
# Values may be empty
# VAR =
# Example:
# HOUDINI_NO_SPLASH = 1
# htoa config start
export HOUDINI_PATH = "htoa-5.0.0_rcd870fd_houdini-17.5.425/htoa-5.0.0_rcd870fd_houdini-17.5.425"
PXR_PLUGINPATH_NAME = "/home/workstationfx/htoa/htoa-5.0.0_rcd870fd_houdini-17.5.425/htoa-5.0.0_rcd870fd_houdini-${HOUDINI_VERSION}/hydra"
# htoa config end
if there is a problem please tell me
man thanks
ali mahdavi
Tags (2)
Labels (2)
1 REPLY 1
in reply to: ali.mahdavi.fx
The second path is for Houdini 18.0 not houdini 17.5 Solidangle or Autodesk should correct this, since Houdini 17.5 doesn't have karma
