Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
[hick] Interrupt render (deltas) IPR error
3 REPLIES 3
378 Views, 3 Replies
I getting the below error quite often when using the renderivew as IPR using HtoA.
It happens roughly 8 out 10 times whenever I try and change a value in my shader network, like a ramp, switch node, etc. - I am coming from Maya so perhaps the interactivity is not quite on par or is there a setting I should know about?
If any other info is required let me know please.
Klaus
Labels (2)
3 REPLIES 3
Stephen.Blair
That's not an error, it's an information message. It's telling you that the IPR render is interrupted because changes (deltas) are being processed.
// Stephen Blair
// Arnold Renderer Support
julian.hodgson
We will change this to be a Debug only message though to be less verbose.
Yep okay, that is what I thought! I actually had it on debug mode already so perhaps that is why that message came through.
Its worth noting that I do not feel I can simply "restart render with the current shadows maps", and often I have to hit the "stop rendering" button and then hit "render" again before it kicks in again.
Thanks again
