Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
hdr color space
2 REPLIES 2
r.nieuwenhuis
131 Views, 2 Replies
hdr color space
I'm struggling a bit with how to setup a domelight in solaris with a hdri file as the texture.
Doing this outside solaris is pretty straightforward, but in solaris It seems like the hdr file is being interpreted with a wrong color space, and I can't find where to set it.
So i thought, well, then I'll make a shader, and get the image in there where I can set the color space, and then set this shader to the dome-light, but it doesn't matter what colorspace I define in the shader, the image looks washed out in the viewport.
What would be the correct way to do this?
Cheers
Rudi
2 REPLIES 2
peterDTE7K
in reply to: r.nieuwenhuis
This might happen if you don't have Arnold Render Settings node connected in LOP tree
r.nieuwenhuis
in reply to: peterDTE7K
Thanks, that seems to be what I overlooked 🙂
