Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
displacement is not working on MaterialX look assignment.
5 REPLIES 5
441 Views, 5 Replies
I am using .mtlx file to assign look on the mesh.
I exported the .mtlx file using arnold rop node. When I connect look through materialx node, Look assignment works great, I got the exact look but displacement is missing.
There is no error found on the log. It is clean as usual.
Can you please look in to it?
Tags (1)
Labels (1)
5 REPLIES 5
Stephen.Blair
It works for me (HtoA 5.0.0). I tested with a mtlx exported from Maya, which I applied to a procedural.
What's your log verbosity? Set it to Debug to check that the operators were actually applied (eg the selection expression is valid).
// Stephen Blair
// Arnold Renderer Support
in reply to: Stephen.Blair
I have checked the log. all the operators have been passed to arnold successfully. No errors. I have attached the file link. Can you please check?
link: google-drive-link
Stephen.Blair
I did my own test, from scratch, and it worked.
// Stephen Blair
Stephen.Blair
It's a problem with the geom paths in the mtlx file.
surface shading is using paths like geom="/obj/emily/alembic:6", which work.
displacement is using geom="/emily_geo/Emily_head_trans/Emily_head_mesh", which doesn't work
// Stephen Blair
Yes, thank you so much. It is working if I manually change the value in emily.mtlx file, but One thing I dont get it, by default How arnold writes in the emily.mtlx file displacement ../image1_material_disp_map" geom="/emily_geo/Emily_head_trans/Emily_head_mesh" ? It is suppose to write like ../image1_material_disp_map" geom="/obj/emily/alembic:6".
am I doing anything wrong?
