Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Deep EXR - Edging issues when rendering deep data as new AOV or layer
2 REPLIES 2
am_wilkins
241 Views, 2 Replies
Good day,
I'm having some issues with unexpected edging only when rendering a layer separately as DeepEXR or also when I create a new RGBA AOV set to DeepEXR and then use the DeepRecolor node in Nuke.
If I render the entire layer and all the AOV as a DeepEXR, then I get the expected behavior and don't get edging issues.
Entire Layer + all AOV when set to DeepEXR.
Correct
EXR layer for the RGB and a new layer or even a RGBA AOV as DeepEXR.
Incorrect
Nuke setup.
Does anyone know why this would be happening? The Deep data should be exactly the same.
Of course there is a big down-side when rendering the entire layer and all the AOV as Deep and I'd like to avoid that.
Hoping to simply have a RGBA AOV as Deep.
All the best,
Andrew
Houdini: 19.0.383
HotA: 6.1.1.1
Arnold  Core: 7.1.1.1
Tags (1)
2 REPLIES 2
Stephen.Blair
in reply to: am_wilkins
Sorry, I'm a bit confused about "layer". Is that a USD layer? Or something like a Maya render layer?
// Stephen Blair
// Arnold Renderer Support
am_wilkins
in reply to: Stephen.Blair
Hi there Stephen,
Yes, in this case I'm referring to a "Render Layer"
Somehow using the "DeepRecolor" workflow to add the Deep info into Nuke is still yielding in the edging issues.
I have read the Arnold docs here:
https://docs.arnoldrenderer.com/display/A5AFHUG/Deep+OpenEXR
Noted that a DeepRecolor method was used here too.
Will try a simpler test scene, but I'm using all pretty much vanilla "Arnold ROP" and nodes in Nuke.
Just appears like there is some difference between directly doing a DeepMerge on the DeepEXR VS doing the DeepRecolor way. Very strange.
