Cryptomatte with husk
cvnc
cvnc
Attempting to render out cryptomatte with the husk render command but having no luck. Using the sick render command outputs an exr that has the cryptomatte metadata and the required AOV's. The generated exr via husk has no cryptomatte metadata but does have the cryptomatte AOV's.
Have attached a hip file. Houdini 19.5, Arnold 7.1.4.1, HtoA 6.1.4.1.
Replies (25)
Stephen.Blair
@martinkindl83 wrote:
t still seems to be an issues, that crypto doesnt render with Husk
is there any ETA to fix this?
With the arnold product type it does work.
// Stephen Blair
// Arnold Renderer Support
Stephen.Blair
And with 5.6.3.1, raster and cryptomatte works for me
// Stephen Blair
martinkindl83
Hello Stephen
im running 6.3.5.0
Using Arnold renderProduct i get crypto when i dont use Override Output Image on USD render ROP. If i enable and fill in custom file output location - thats how pipe dictates where we safe files, we dont get any crypro.
With raster renderProduct option, crypto doesnt work at all
Stephen.Blair
For raster, use 6.3.5.1
The Override Output Image is a known issue, and iirc it's on SideEffects side of the fence
// Stephen Blair
martinkindl83
Thank you. Will check with sidefx. You know if it affects Karma as well, if it's Sidefx side of things?
Stephen.Blair
No, it's with custom product types like Arnold.
// Stephen Blair
