Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Cryptomatte Sidecar Manifests in Solaris
0 REPLIES 0
Message 1 of 1
macbeth.rene
208 Views, 0 Replies
Hi is it possible to enable sidecar manifests in the new arnold_cryptomatte_aovs hda?
I try adding the following line to the code inside the hda at line number 84:
crypto_shader.CreateInput('sidecar_manifests', Sdf.ValueTypeNames.Bool).Set(True)
when rendering with usd render rop (Husk), it actually does not write the manifest to the exr, but does not write the json file either.
Can something be done? or done in such a way within solaris that Kick will write the json even if husk cant ?
Thanks in advance!
Labels (1)
0 REPLIES 0
