Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
CPU only render failure
2 REPLIES 2
phillips.a.adam
118 Views, 2 Replies
My render keeps failing on CPU which is annoying as this works just fine when I switch the device over to GPU. On CPU my render fails and gets cranky about a file name. Has anyone had this/or can shed light on it?
Error
Command Exit Code: -6
00:00:00 100MB | [hick] Received: AA: 4 4
00:00:00 100MB | [hick] Received: begin
00:00:00 100MB | [hick] Batch mode
00:00:00 100MB | log started Tue Oct 25 22:04:55 2022
00:00:00 100MB | Arnold 7.1.3.2 [2a385cac] windows clang-10.0.1 oiio-2.4.1 osl-1.12.0 vdb-7.1.1 adlsdk-6.3.1.44 clmhub-2.0.0.235 rlm-14.1.3 optix-6.6.0 2022/09/12 08:50:17
00:00:00 100MB | running on DESKTOP-B93T021, pid=19452
00:00:00 100MB | 1 x AMD Ryzen Threadripper PRO 3975WX 32-Cores (32 cores, 64 logical) with 130912MB
00:00:00 100MB | NVIDIA driver version 517.40 (Optix 60803)
00:00:00 100MB | GPU 0: NVIDIA RTX A5000 @ 1695MHz (compute 8.6) with 24563MB (22230MB available) (NVLink:0)
00:00:00 100MB | Windows 10 (version 10.0, build 19043)
00:00:00 100MB | soft limit for open files changed from 512 to 2048
00:00:00 100MB |
00:00:00 100MB | [metadata] loading metadata file: C:\Users\User\htoa\htoa-6.1.3.3_rdb15014_houdini-19.0.720\htoa-6.1.3.3_rdb15014_houdini-19.0.720\scripts\bin\arnold.mtd
00:00:00 117MB | [color_manager_ocio] default ocio.config found in C:\Users\User\htoa\htoa-6.1.3.3_rdb15014_houdini-19.0.720\htoa-6.1.3.3_rdb15014_houdini-19.0.720\scripts\bin\../ocio/configs/arnold/config.ocio
00:00:00 117MB | loading plugins from C:\Users\User\htoa\htoa-6.1.3.3_rdb15014_houdini-19.0.720\htoa-6.1.3.3_rdb15014_houdini-19.0.720\scripts\bin\..\plugins ...
00:00:00 117MB | alembic_proc.dll: alembic uses Arnold 7.1.3.2
00:00:00 117MB | [metadata] loading metadata file: C:\Users\User\htoa\htoa-6.1.3.3_rdb15014_houdini-19.0.720\htoa-6.1.3.3_rdb15014_houdini-19.0.720\scripts\bin\..\plugins\alembic_proc.mtd
00:00:00 117MB | cryptomatte.dll: cryptomatte uses Arnold 7.1.3.2
00:00:00 117MB | cryptomatte.dll: cryptomatte_filter uses Arnold 7.1.3.2
00:00:00 117MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 7.1.3.2
00:00:00 117MB | [metadata] loading metadata file: C:\Users\User\htoa\htoa-6.1.3.3_rdb15014_houdini-19.0.720\htoa-6.1.3.3_rdb15014_houdini-19.0.720\scripts\bin\..\plugins\cryptomatte.mtd
00:00:00 118MB | htoa_mandelbulb_proc.dll: mandelbulb uses Arnold 7.1.3.2
00:00:00 118MB | [metadata] loading metadata file: C:\Users\User\htoa\htoa-6.1.3.3_rdb15014_houdini-19.0.720\htoa-6.1.3.3_rdb15014_houdini-19.0.720\scripts\bin\..\plugins\htoa_mandelbulb_proc.mtd
00:00:00 122MB | usd_proc.dll: usd uses Arnold 7.1.3.2
00:00:00 122MB | [metadata] loading metadata file: C:\Users\User\htoa\htoa-6.1.3.3_rdb15014_houdini-19.0.720\htoa-6.1.3.3_rdb15014_houdini-19.0.720\scripts\bin\..\plugins\usd_proc.mtd
00:00:00 122MB | loaded 6 plugins from 4 lib(s) in 0:00.08
00:00:00 141MB | [color_manager_ocio] default ocio.config found in C:\Users\User\htoa\htoa-6.1.3.3_rdb15014_houdini-19.0.720\htoa-6.1.3.3_rdb15014_houdini-19.0.720\scripts\bin\../ocio/configs/arnold/config.ocio
00:00:00 141MB | [hick] Start
00:00:00 141MB | [hick] Received: log_verbosity: 3590
00:00:00 141MB | [hick] Received: log_console_enable: 1
00:00:00 141MB | [hick] Received: log_file:
00:00:00 141MB | [hick] Received: log_max_warnings: 5
00:00:00 141MB | [hick] Received: delta_publisher_port: 59289
00:00:00 141MB | [hick] Received: threads: 0
00:00:00 141MB | [hick] Received: assfile: c:\users\user\appdata\local\temp\houdini_temp\htoa_User\31992_d93c8d79-0625-4025-a3e3-472f8268e8d8.ass
00:00:00 145MB | [metadata] loading metadata file: c:\users\user\appdata\local\temp\houdini_temp\htoa_User\31992_d93c8d79-0625-4025-a3e3-472f8268e8d8.ass
00:00:00 146MB | [ass] loading c:\users\user\appdata\local\temp\houdini_temp\htoa_User\31992_d93c8d79-0625-4025-a3e3-472f8268e8d8.ass ...
00:00:01 671MB | [ass] read 332479784 bytes, 74 nodes in 0:00.59
00:01:53 6588MB ERROR | [texturesys] could not read resolved image filename = "D:/clientname/geo/Bathroom_Sink/Maps/roundsSink_02_v1/roundSink_v2002_Porcelin_BaseColor.1013.exr"
00:01:53 6588MB ERROR | [texturesys] could not read resolved image filename = "D:/clientname/geo/Bathroom_Sink/Maps/roundsSink_02_v1/roundSink_v2002_Porcelin_Roughness.1013.exr"
00:01:53 6588MB WARNING | render terminating early: received abort signal
00:01:58 3871MB | [hick] Render terminated
00:01:58 3871MB | [hick] Exit code -6
00:01:58 3818MB |
00:01:58 3818MB | releasing resources
00:01:58 458MB |
00:01:58 458MB | releasing resources
00:01:58 440MB | unloading 4 plugins
00:01:58 440MB | closing alembic_proc.dll ...
00:01:58 440MB | closing cryptomatte.dll ...
00:01:58 440MB | closing htoa_mandelbulb_proc.dll ...
00:01:58 440MB | closing usd_proc.dll ...
00:01:58 437MB | unloading plugins done
00:01:58 437MB | Arnold shutdown
2 REPLIES 2
Could not read resolved image file, it says, so my guess, D:/clientname/geo/Bathroom_Sink/Maps/roundsSink_02_v1/roundSink_v2002_Porcelin_Roughness.1013.exr is not present. Maybe there is some "leftover" stuff that ended up by accident in tile 1013, because 13 udim tiles for a porcelin round sink sounds like overkill. I would check the uv's of that geo.
Thanks @rudi.nieuwenhuis! I solved the problem and it had nothing to do with UVs. The camera is going prettty close on an 8k+ render so unfortunately I do require that much resolution.
my question was why everything was working fine on a GPU render and then aborts because of this issue on CPU setting? It’s a real head scratcher.
the underlying cause is a dodgy exr from substance painter - I solved this by importing and then exporting from Mari which does a much better job with writing data it seems. Dodgy Adobe development I guess.
