Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Could not find AOV with source... not RGB,
3 REPLIES 3
290 Views, 3 Replies
Anyone know the correct workflow for denoising custom AOVs with noice in Houdini? specifically the setup.
All the documentation seems maya specific. (I can't create a separate driver without creating a separate output path, (which noice is then unable to see)) So should changing the custom aov filter to variance+setting type to RGB + enabling output varianceAOV just work?
HtoA 5.1 arnold 6.0.2.0
Any help much appreciated
Labels (3)
3 REPLIES 3
submitting to noice gives the error
ok Noice will work if run via CMD Prompt with -i for each outputted AOV. The gui in houdini doesn't seem to accommodate multiple input images. If you expose the 'noice command' the input tab is just a string prepended with a single -i
Stephen.Blair
You don't need another ROP, because HtoA lets you specify a layer name, and noice can use that
// Stephen Blair
// Arnold Renderer Support
Technology Administrators
