Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
COPS to HDRI
3 REPLIES 3
phillips.a.adam
259 Views, 3 Replies
COPS to HDRI
In Vray I can take an HDRI image through cops, do stuff (Blur, composite things etc) and link this to a skydome. Is there a way I can do this in arnold? Linking a COPS end of network null in the texture slot gets me either nothing or a white skydome.
Tags (1)
Labels (1)
3 REPLIES 3
Whatever you link to a skydome color has to be a file (tx or exr, jpg, png, tif). All texture input to Arnold goes through OpenImageIO, which is file based.
// Stephen Blair
// Arnold Renderer Support
Hi Stephen,
could you clarify your answer?
Here’s what I do I Vray:
Import hdri file in COPS, do OCIO color transform using a COP VOP, attach a Defocus node if I want to blur the hdri and then attach a null. I point the skydome at this null. Effectively this gives me an adjustable HDRI in COPS.
Can I do this in Arnold, or does it not allow for COps usage? If that’s the case, is there a way to blur the hdri on the go without having to save out multiple versions of the hdri file?
You cannot use COPs, that's not supported yet.
Arnold needs a texture file from disk.
There's no Arnold blur node, so I think you'd have to have multiple versions.
// Stephen Blair
