Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
clipping planes not working
7 REPLIES 7
Message 1 of 8
284 Views, 7 Replies
It seems like no matter what I do cliiping planes dont work.
I get this error with every render: cameraProperties: near_clip is greater than or equal to far_clip
Tags (2)
Labels (2)
7 REPLIES 7
Message 2 of 8
Stephen.Blair
I don't get any errors with HtoA 6.0.1 and Houdini 18.5.696
cameraProperties is the name of the camera?
What if you create a new camera, does it have the same problem.
What are the near and far clip values you are using?
// Stephen Blair
// Arnold Renderer Support
Message 3 of 8
in reply to: Stephen.Blair
I am using htoa 6.0.0 and houdini 18.5.462
sorry i cut off the name, its called render_camera
it does persist
0.1-100
Message 4 of 8
Stephen.Blair
What about a new scene? Same problem?
Can you try with the latest HtoA?
// Stephen Blair
Message 5 of 8
@Stephen Blair I am getting this:
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: position (ar_position)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: look_at (ar_look_at)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: up (ar_up)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: matrix (ar_matrix)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: handedness (ar_handedness)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: near_clip (ar_near_clip)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: far_clip (ar_far_clip)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: screen_window_min (ar_screen_window_min)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: screen_window_max (ar_screen_window_max)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: shutter_start (ar_shutter_start)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: shutter_end (ar_shutter_end)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: motion_start (ar_motion_start)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: motion_end (ar_motion_end)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: cameratype (ar_cameratype)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: units (ar_units)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: sensor_width (ar_sensor_width)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: enable_dof (ar_enable_dof)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: fstop (ar_fstop)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: focus_dist (ar_focus_dist)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: lens_model (ar_lens_model)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: wavelength (ar_wavelength)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: extra_sensor_shift (ar_extra_sensor_shift)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: focal_length_lentil (ar_focal_length_lentil)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: optical_vignetting_distance (ar_optical_vignetting_distance)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: optical_vignetting_radius (ar_optical_vignetting_radius)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: abb_spherical (ar_abb_spherical)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: abb_distortion (ar_abb_distortion)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: bokeh_circle_to_square (ar_bokeh_circle_to_square)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: bokeh_anamorphic (ar_bokeh_anamorphic)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: bokeh_aperture_blades (ar_bokeh_aperture_blades)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: bokeh_enable_image (ar_bokeh_enable_image)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: bokeh_image_path (ar_bokeh_image_path)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: bidir_min_luminance (ar_bidir_min_luminance)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: bidir_sample_mult (ar_bidir_sample_mult)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: bidir_add_luminance (ar_bidir_add_luminance)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: bidir_add_luminance_transition (ar_bidir_add_luminance_transition)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: bidir_debug (ar_bidir_debug)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: vignetting_retries (ar_vignetting_retries)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: abb_coma (ar_abb_coma)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: cryptomatte (ar_cryptomatte)
00:00:00 4173MB WARNING | [htoa.node.node] [soho] Parameter not found: name (ar_name)
Message 6 of 8
Stephen.Blair
Most of that looks like lentil spare parameters
// Stephen Blair
Message 7 of 8
Oh yes this is unrelated you are right.
In the ass file its returning 0 for both, is it possible that because its getting values from a channel its not correct?
Message 8 of 8
Stephen.Blair
Sounds like it. Can you give me an example hip?
// Stephen Blair
