Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
cell noise to volume displacement tutorial
21 REPLIES 21
Message 1 of 22
alnhDBHYS
628 Views, 21 Replies
I'm not getting any displacement at all when I do this tutorial:
https://docs.arnoldrenderer.com/display/A5AFHUG/Cell+Noise+to+Volume+Displacement+Animation
I tried downloading the sample file to my mac and when I unzip it, I get a directory structure that looks like a houdini scene but I don't see how to open it.
Does anyone have a sample scene I might have a look at to see where I may have gone wrong?
Tags (1)
Labels (1)
21 REPLIES 21
Message 2 of 22
lee_griggs
in reply to: alnhDBHYS
The file was set to the persp camera. I have since saved it with the RenderCam as the viewport now, so you should just see this when you render.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 22
alnhDBHYS
Thanks Lee. I don't get a houdini scene when I unzip that file - but a directory structure. Is there a trick to opening this file?
Message 4 of 22
alnhDBHYS
Ok I was able to download the hip file now. I had to copy the link - for some reason clicking on it downloaded a ".zip" file.
Cheers
Message 5 of 22
lee_griggs
Sorry, I am not on Mac so I can't test it. Yes, most downloads use .zip in the docs. Glad you got it working.
Lee Griggs
AUTODESK
Message 6 of 22
alnhDBHYS
in reply to: lee_griggs
Thanks again. I found that if I do: "unzip -j /path/to/file.zip" I get the hip file instead of directories. I guess my mac is confusing the structure of the hip file with file folders without -j.
(https://unix.stackexchange.com/questions/72838/unzip-file-contents-but-without-creating-archive-fold...)
Message 7 of 22
tw3
c4dtoA
I can't get the gradient to 'grow' the effect.
any one any ideas what I'm missing.
I have the sample file and same issue . . .
thanks
Message 8 of 22
lee_griggs
in reply to: tw3
What do you mean? Animate the ramp?
Lee Griggs
AUTODESK
Message 9 of 22
m.alexpisoi
Hi, I know it might be too late to ask for tips about this tutorial but I'm having some issues while using it on Maya 2023.
I've built the setup as was indicated in the tutorial but it doesn't work at all. I have no clue about what could be wrong.
I've attached a few screenshots showing my Hypershade setup, the catclark subdivisions and what I see in the Render View.
Any suggestions?
Message 10 of 22
lee_griggs
Have you tried the scene file here?
Lee Griggs
AUTODESK
Message 11 of 22
m.alexpisoi
Yes I have, but still nothing... I tried playing with the values to try and see some change but the Sphere on which I've applied the material doesn't change at all
Message 12 of 22
lee_griggs
It renders fine for me. Are you using the latest build?
Lee Griggs
AUTODESK
Message 13 of 22
m.alexpisoi
I'm afraid I'm not sure, at this poit I've just copied the setup from the demo file but it doesn't work.
I also tried to create a sphere in the same scene as the demo file, I applied the material to it and it still doesn't work, not even on the demo file
Message 14 of 22
lee_griggs
This is what I get.
Lee Griggs
AUTODESK
Message 15 of 22
m.alexpisoi
For me it works aswell but only on the demo head, I can't get it to work on any other shape.
I made sure to follow all the instructions,  I don't know what's wrong
This right here is my project, at this point I'm really curious about what the issue could be
Message 16 of 22
lee_griggs
Have you added a step_size to the object as in the screenshot?
Lee Griggs
AUTODESK
Message 17 of 22
m.alexpisoi
Yes, I did. I followed every instruction triple checking everything 😞
Message 18 of 22
lee_griggs
Can you attach your scene (simplified) here?
Lee Griggs
AUTODESK
Message 19 of 22
m.alexpisoi
Here it is
Message 20 of 22
lee_griggs
I would need the textures as well.
Lee Griggs
AUTODESK
