Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Cant start arnold
1 REPLY 1
250 Views, 1 Reply
Cant start arnold
Hi, downloaded last arnold build, logined with trial mode, but cant load materials (it`s not showing up), if i set light - it shows errors. houdini 18.5.462. Not rendering at all.
Tags (1)
Labels (1)
1 REPLY 1
Stephen.Blair
First, how to do you start Houdini? Don't double-click on a hip file, that won't work because the Houdini environment won't be set up correctly.
What's your houdini.env look like?
You want something like this (PATH is for Windows only):
# htoa config start
PATH = "$PATH;C:/solidangle/htoa/htoa-5.6.0.0_r370661f_houdini-18.0.597/htoa-5.6.0.0_r370661f_houdini-${HOUDINI_VERSION}/scripts/bin"
HOUDINI_PATH = "C:/solidangle/htoa/htoa-5.6.0.0_r370661f_houdini-18.0.597/htoa-5.6.0.0_r370661f_houdini-${HOUDINI_VERSION};&"
# htoa config end
Check Help > About Houdini > Show Details
You want to see the HtoA location at the start of HOUDINI_PATH
If you have other renderers and plugins, I would remove all other plugins from HOUDINI_PATH, get HtoA working, and then put the other stuff back.
// Stephen Blair
// Arnold Renderer Support
