Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Cannot add nodes in Arnold Vop
11 REPLIES 11
Message 1 of 12
singhs_apps
1237 Views, 11 Replies
Hello
I am having trouble adding nodes in the VOP networks in Houdini 16.5 (Indie) with Arnold 5
When I enter the Arnold_Vop net I see no option to add nodes. Similarly, while I can add an Arnold Standard Shader node in SHOP, once I enter it, again I cannot see any way to add nodes.
The only two options available are
- Null
- Subnetwork
Tags (2)
Labels (2)
11 REPLIES 11
Message 2 of 12
This is an installation problem. probably your HOUDINI_PATH is not set up correctly yo include the HtoA install directory. Did you install Redshift? Can you show your houdini.env file contents?
Message 3 of 12
singhs_apps
in reply to: singhs_apps
I don't have Redshift.
Houdini env file contents :
# # Houdini Environment Settings # # The contents of this file are read into the environment # at startup. They will override any existing entries in # the environment. # # The syntax is one entry per line as follows: # VAR = VALUE # # Values may be quoted # VAR = "VALUE" # # Values may be empty # VAR = # # Example: # # HOUDINI_NO_SPLASH = 1
# htoa config start HOUDINI_PATH = "/Users/mukeshsingh/htoa/htoa-2.2.2_ra19eea7_houdini-16.5.323/htoa-2.2.2_ra19eea7_houdini-${HOUDINI_VERSION};&" # htoa config end
RMANTREE = /Applications/Pixar/RenderManProServer-21.6
PATH = /Applications/Pixar/RenderManProServer-21.6/bin:$PATH
HOUDINI_OCL_DEVICENUMBER = 1
Message 4 of 12
your path should be like this:
# htoa config start
# htoa config end
Message 5 of 12
singhs_apps
It is as you have posted.
Copying the env file contents into the editor formats it.
Message 6 of 12
You have only HOUDINI_PATH variable, where is the PATH variable?
reinstall or replace your env file with this one:
PATH = "$PATH;/Users/mukeshsingh/htoa/htoa-2.2.2_ra19eea7_houdini-16.5.323/htoa-2.2.2_ra19eea7_houdini-${HOUDINI_VERSION}/scripts/bin"
Message 7 of 12
singhs_apps
I am not sure I follow you. The env variable was automatically set when I Installed Arnold. Adding the extra line as per your suggestion above returns the same error as my original post.
Message 8 of 12
Can you double check that that HOUDINI_PATH line starts with a new line? It looks like it starts with a comment in the text that you posted.
Message 9 of 12
singhs_apps
The Houdini Path is on a single line :
I removed the htoa folder and reinstalled Arnold. The error persists.
@rachid Hadj Abderrahmane
The second line you suggested isn't required on macOS.
Reiterating my issue :
I can launch the Arnold render node. I can even Render using Arnold.
I just can't create any nodes inside of Arnold Standard shader or Arnold Vop Network.
Message 10 of 12
Stephen.Blair
Arnold Standard is deprecated, so forget about using that. Standard Surface is the shader to use.
Can you start Houdini from a Houdini terminal? Then you should get an HtoA startup log. If you don't, then increase the log verbosity and get an Arnold log for a test render. And get the Show Details from Help > About Houdini.
// Stephen Blair
// Arnold Renderer Support
Message 11 of 12
singhs_apps
It seems the online Document is sparse and out of date. Arnold v5 has a slightly convoluted way to build shaders inside of Houdini.
Step 01: Build a test geometry, add Camera and Arnold light in the OBJ context
Step 02: Enter SHOp context, build Arnold Vop Node. Dive inside
Step 03: create "subnetwork"node, dive inside and create your shader network.
Message 12 of 12
singhs_apps
@Stephen Blair
How do I start Houdini from a terminal on mac os?
I can create shaders, render etc via Arnold.
It's just that unlike the tutorials and online documents of Arnold to Houdini, The Arnold vopnet shows only two options - option to add a null node and a subnet node. I can dive inside the subnet and create shaders, but that's diving one extra level deep just to create shaders when I am already inside an Arnold vopnet.
Is that an expected behaviour ?
