Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Candidate Lights vs. Force Lights
2 REPLIES 2
mail
169 Views, 2 Replies
Houdini 15.5.351
HtoA 4.1.2
Arnold 5.3.1.1
I've encountered a strange behavior in Houdini: If I put an arnold light into "Force Lights" on an arnold ROP and render, Arnold still takes the "Enable Light" toggle into account. In Mantra/Karma whether the light is Enabled/Disabled only matters for Candidate Objects. If a light is added via Force Lights it does not matter whether enabled or not, it will show up in this render.
Even according to the Arnold documentation this seems to should be the case: https://docs.arnoldrenderer.com/display/A5AFHUG/Main
"Force Lights
The lights in this parameter are added to the render regardless of whether the light is enabled."
However in my Houdini/Arnold version the light will only show up in the render if it's enabled - even if added via Force Lights.
Is this a bug or doing something else I'm not seeing?
2 REPLIES 2
Stephen.Blair
in reply to: mail
It was a bug but it was fixed way back in HtoA 5.6
// Stephen Blair
// Arnold Renderer Support
mail
in reply to: mail
Ah yeah I see it here:
htoa#982 Fix forcelights parameter on the Arnold ROP
Thanks a bunch!
