Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Can't use arnold in houdni 18.0.391
2 REPLIES 2
nezgro79
417 Views, 2 Replies
Hi i need to install the demo version of arnold on my new computer but after the installation i cant use arnold in houdini, he doesn't appear in the output setting.
I have tried older version of arnold and houdini and is the same problem.
when if i remove the render man line i have the same trouble
But on my other computer its ok
there is my env file
# Houdini Environment Settings
# The contents of this file are read into the environment
# at startup. They will override any existing entries in
# the environment.
# The syntax is one entry per line as follows:
# VAR = VALUE
# Values may be quoted
# VAR = "VALUE"
# Values may be empty
# VAR =
# Example:
# HOUDINI_NO_SPLASH = 1
# htoa config start
HOUDINI_PATH = "/home/bgood/htoa/htoa-5.1.1_r126b954_houdini-18.0.391/htoa-5.1.1_r126b954_houdini-${HOUDINI_VERSION};&"
# htoa config end
RMANTREE=/opt/pixar/RenderManProServer-23.1
RFHTREE=/opt/pixar/RenderManForHoudini-23.1
HOUDINI_PATH=$RFHTREE/18.0:&
HOUDINI_OCL_DEVICETYPE=GPU
Tags (2)
Labels (2)
2 REPLIES 2
Stephen.Blair
in reply to: nezgro79
You have two lines that set HOUDINI_PATH and the last one wins
// Stephen Blair
// Arnold Renderer Support
nezgro79
Yes it's ok now thank you
