Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
bake selected geometry in HtoA?
2 REPLIES 2
gshankar165
544 Views, 2 Replies
I have a geometry with procedural displacement shader in Houdini.
is this option Arnold -> Utilities -> Bake selected Geometry (just like maya) available in HtoA to bake displaced geometry into ass or something?
If not, are you implementing it on upcoming HtoA version?
Labels (3)
2 REPLIES 2
jan.schoeman
in reply to: gshankar165
Nope, that's a maya only feature.
What you can do is to, in the Arnold material, reroute the displacement through a flat node into the surface input and bake it to an EXR.
https://docs.arnoldrenderer.com/display/A5AFHUG/Baking
Then subdivide your mesh appropriately, transfer the displacement values from the map to the points using an attribute from map node, and displace it in a point vop with displace along normal.
gshankar165
in reply to: jan.schoeman
thanks for the update.
