Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
ASS.File or Alembic for fastest render?
1 REPLY 1
eddi_fuhrmann
2014 Views, 1 Reply
Working a lot with instancing at the moment and was wondering what the most efficient workflow is. tried alembis and ass. files but could not make a big difference. is there some one who has a bit more indepth knowledge? greetings!
Tags (1)
Labels (1)
  • ass
1 REPLY 1
Both are a form of procedurals. .ASS files I are maybe slightly quicker because they're the native scene description format but if you look at the .ass file when rendering an Alembic procedural you'll see they are very similar.
Personally it depends on your workflow/pipeline. You will find more efficiency with as few steps as possible. If all of your assets are already Alembic you might as well instance those. I have rendered massive environments with both and the only real difference was how I set up the instance container.
Technology Administrators
