Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Arnold watermark when rendering through PDG
2 REPLIES 2
alainh3d
160 Views, 2 Replies
I have a very simple scene, generating objects from a csv file.
Then I want to render the objects from two different cameras.
I use 2 different ropfetch nodes combined with a partition by index to do this.
It works perfectly, but it seems that Arnold does not find a license when rendering because I get the watermak on my renders.
However when I render a single frame manually through RenderView, it's all good.
PS: I use Houdini Env to load Arnold, not a json file.
Thank you for your help!
Alain
2 REPLIES 2
francoislord
in reply to: alainh3d
alainh3d
Yes that worked !
Thank you so much @francoislord
