Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Arnold Volume wildcard in ar_grids parameter
3 REPLIES 3
seals77
285 Views, 3 Replies
when setting up VDB volumes with Arnold Volume OBJ node, there is Grids parameter. When clicking on drop-down menu, it shows available grids and it also shows * (all grids) option, which should import all available grids.
Using wildcard in Grids parameter however does not work, Arnold outputs this warning:
00:00:00   102MB WARNING |   [volume] could not find non-empty "grids" user data, cannot create volume
Do you plan fixing this bug? I have a situation where I have changing names of grids each frame and using wildcard for importing all of them would help me.
Workaround for now I guess will be using some Python expression, which will return all grids.
Juraj
3 REPLIES 3
seals77
in reply to: seals77
Also in your docs you have an example image which has wildcard in it.
Stephen.Blair
Yes, now that the issue has been reported and I've logged it, you can expect it to be fixed.
// Stephen Blair
// Arnold Renderer Support
seals77
Awesome, thank you 🙂
