Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Arnold shaders not showing in Houdini SHOP Network
9 REPLIES 9
Message 1 of 10
mauricioferreiramaia
622 Views, 9 Replies
Hey,
I'm having problems to deal with Arnold. I can't find most of the shaders inside of arnold_vopnet. I was trying to use Standard Surface shader and it is simply not there. I don't know if it is a common thing, but I'm quite lost here.
Thanks in advance.
Tags (1)
Labels (1)
9 REPLIES 9
Message 2 of 10
in reply to: mauricioferreiramaia
Something wrong in your houdini.env file or json file, maybe you have Renderman conflicting with Arnold!
Message 3 of 10
That means the environment (eg houdini.env) is set up incorrectly.
How do you open the scene files? By double-clicking them? That causes problems.
Otherwise, check houdini.env
// Stephen Blair
// Arnold Renderer Support
Message 4 of 10
I tried to open the .hip file by right clicking on it and the shaders are still not there.
Thanks.
Message 5 of 10
I don't know. I never used Renderman, only Mantra.
Thanks!
Message 6 of 10
Use File > Open in Houdini.
And can you get Help > About Houdini > Show Details ?
// Stephen Blair
Message 7 of 10
wow. It works! 🙂 Will I need to this forever ?
Many thanks!
Message 8 of 10
The env file look correct, do you have others environment variable in you OS ?
Message 9 of 10
also happen if you start the wrong houdini version, HtoA need always specific houdini version.
Message 10 of 10
Have you resolve it?, I have same problem can anyone help me?
