Arnold shader nodes not showing in Houdini
Message 1 of 15
01_img.pngI'm trying to create a basic material, I can create the Arnold Shader Network but if I dive into it there is no Standard surface nor any other shader.
I guess the Env. file is set up correctly since the Arnold tab is present, so I don't understand what I'm doing wrong.
I'll attach a picture, thanks in advance for the help.
Replies (14)
Message 2 of 15
pal.mezei
Hi!
Can you share your environment with us? Go to Help / About Houdini / Show Details, press Save and share the resulting file.
Cheers,
Pal.
Message 3 of 15
pablo_gazquez
Houdini_Info.txt
the same problem
Message 4 of 15
Stephen.Blair
How do you start Houdini? Start it from the Houdini Command Line Tools, don't double click on a hip file.
// Stephen Blair
// Arnold Renderer Support
Message 5 of 15
pablo_gazquez
Message 6 of 15
pal.mezei
Hi!
I think I found your issue. Looking at the env file, I noticed that the HTOA folders are present twice both in PATH and HOUDINI_PATH, and doing the same thing locally broke my shaders.
You can try the following:
Locate your houdini.env file (should be in C:\Users\pablo\Documents\houdini18.0) and make sure the PATH and HOUDINI_PATH contains the HTOA folders only once.
It should look like if you are using the HtoA installer:
# htoa config start
PATH = "$PATH;C:/Users/pablo/htoa/htoa-5.3.0_r233605f_houdini-18.0.499/htoa-5.3.0_r233605f_houdini-${HOUDINI_VERSION}/scripts/bin"
HOUDINI_PATH = "C:/Users/pablo/htoa/htoa-5.3.0_r233605f_houdini-18.0.499/htoa-5.3.0_r233605f_houdini-${HOUDINI_VERSION};&"
# htoa config end
After this, go to control panel / system / advanced system settings / environment variables and make sure PATH or HOUDINI_PATH does not contain any htoa specific folders there. (and logout/login if you do remove something from there)
After all this, reopen Houdini and the shader nodes should be visible again.
Please let me know if this works for you.
It seems that having HtoA twice in HOUDINI_PATH is the culprit. (same thing happens with HtoA 5.4)
Message 7 of 15
Stephen.Blair
If you double-click a hip file, that runs a different executable (eg on Windows, hview), and the environment is set differently (with the two entries that cause the problem)
// Stephen Blair
Message 8 of 15
pablo_gazquez
How I can start Houdini with Houdini Command Line Tools step by step ??
Message 9 of 15
pablo_gazquez
It doesnt work for me 😞
Message 10 of 15
Stephen.Blair
It's in the Windows Start menu, under Side Effects Software > Houdini > Utilities
Then run houdini or houdinifx or hindie
// Stephen Blair
Message 11 of 15
pablo_gazquez
Stephen that was the problem, SUCCESS!!!!!!!!! I`m very happy 🙂
THANKS
Message 12 of 15
opsismotion
Observer
Observer
I have the same problem, I have tried everything and nothing works. I'm going crazy, I've been trying for a week. It's a very expensive product to have so many problems.
Message 13 of 15
biiiped
Observer
Observer
hello,
is there a way to change the env that is used by houdini when double-click on a file?
Message 14 of 15
biiiped
Observer
Observer
okay , so i removed one of the 2 path :
and now it work , i can double click scenes and there is arnold nodes, i just try a bit, i don't know if this will cause other problem later, i hope this is the solution !
Message 15 of 15
921864911
Community Visitor
Community Visitor
Really useful , thank you!
