Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Arnold shader network is not showing in Houdini SHOP Network
9 REPLIES 9
Message 1 of 10
Abhilash_Pradeep_Kumar
694 Views, 9 Replies
Labels (4)
9 REPLIES 9
Message 2 of 10
How do you start Houdini? Don't double click a hip file. Start Houdini from the Houdini Command Line Tools.
// Stephen Blair
// Arnold Renderer Support
Message 3 of 10
I did start from Command Line but it's not working
Message 4 of 10
Does anything about Arnold show up anywhere? Did you see anything logged in the Houdini Console at startup?
// Stephen Blair
Message 5 of 10
Are you sure you are using the right version?
htoa-5.3.0_r233605f_houdini-18.0.499
htoa-5.5.0.1_r45f2926_houdini-18.5.408
Your env is a mix of the 2
“htoa-5.5.0.1_r45f2926_houdini-18.0.499”
Message 6 of 10
in reply to: Abhilash_Pradeep_Kumar
If you are using Windows 10 Pro Verision 20H2
You have to move you env.file from
C:\Users\YOUR_NAME\Documents\houdini18.5
to
C:\Users\YOUR_NAME\OneDrive\Documents\houdini18.5
Message 7 of 10
it shows something like this
Message 8 of 10
Can you post the details from Help > About Houdini > Show Details?
// Stephen Blair
Message 9 of 10
Houdini_Info.txt
I have attached the file
Message 10 of 10
I don't see anything obviously wrong. But there should be more messages logged by HtoA at startup.
Can you get a Process Monitor log? That will show what's happening at startup.
  • Download Process Monitor and extract it to a folder https://technet.microsoft.com/en-us/sysinternals/processmonitor.aspx
  • Start Process Monitor and start capturing events (CTRL+E or the magnifying glass icon)
  • Start Houdini
  • Go back to Process Monitor and stop capturing events
  • Save the Process Monitor log to a .PML file
  • Zip up the log and post it somewhere (such as dropbox, google drive, wetransfer)
// Stephen Blair
