00:00:00 423MB | 1 x Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz (8 cores, 16 logical) with 65536MB
00:00:00 423MB | Mac OS 13.3.0, Darwin kernel 22.4.0
00:00:00 423MB | soft limit for open files changed from 256 to 10238
00:00:00 423MB |
00:00:00 428MB | [color_manager_ocio] default ocio.config found in /Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/scripts/bin/../ocio/configs/arnold/config.ocio
00:00:00 428MB | loading plugins from /Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/scripts/bin/../plugins ...
00:00:00 428MB | cryptomatte.dylib: cryptomatte uses Arnold 7.2.2.1
00:00:00 428MB | cryptomatte.dylib: cryptomatte_filter uses Arnold 7.2.2.1
00:00:00 428MB | cryptomatte.dylib: cryptomatte_manifest_driver uses Arnold 7.2.2.1
00:00:00 432MB | usd_proc.dylib: usd uses Arnold 7.2.2.1
00:00:00 432MB | htoa_mandelbulb_proc.dylib: mandelbulb uses Arnold 7.2.2.1
00:00:00 432MB | alembic_proc.dylib: alembic uses Arnold 7.2.2.1
00:00:00 432MB | loaded 6 plugins from 4 lib(s) in 0:00.07
00:00:00 432MB | [htoa_op] Begin registration ...
00:00:00 432MB | [obj_procedurals] Registering procedurals ...
00:00:00 433MB | [obj_procedurals] procedural registration done.
2023-08-01 19:17:14.898 houdinifx[73863:3052759] GPU <MTLIGAccelDevice: 0x7fcf81c18000>
name = Intel(R) UHD Graphics 630 isn't enable for Redshift
2023-08-01 19:17:14.950 houdinifx[73863:3052759] GPU <MTLIGAccelDevice: 0x7fcf81c18000>
00:00:01 536MB | [rop_operators] Registering operators ...
00:00:01 536MB | [rop_operators] operator registration done.
00:00:01 540MB | [vop_shaders] Registering shaders ...
00:00:01 543MB | [vop_shaders] shader registration done.
00:00:01 543MB | [vop_imagers] Registering imagers ...
00:00:01 543MB | [vop_imagers] imager registration done.
00:00:01 543MB | [htoa_op] USD shader translation registration
00:00:04 577MB | [htoa_op] End registration.
00:00:04 577MB |
00:00:04 577MB | releasing resources
00:00:04 577MB | Arnold shutdown
luke@Lukes-MacBook-Pro ~ % 00:00:00 38MB | [hick] Lowered process priority to 19
00:00:00 38MB | [hick] Received: AA: -3 3
00:00:00 38MB | [hick] Received: interactive 2
00:00:00 38MB | [hick] Received: begin
00:00:00 38MB | [hick] Interactive mode
00:00:00 38MB | log started Tue Aug 1 19:18:30 2023
00:00:00 38MB | Arnold 7.2.2.1 [6b366366] darwin x86_64 clang-15.0.7 oiio-2.4.1 osl-1.12.9 vdb-7.1.1 adlsdk-7.4.2.47 clmhub-3.1.1.43 rlm-14.2.5 2023/06/20 09:33:45
00:00:00 38MB | running on Lukes-MacBook-Pro, pid=73927
00:00:00 38MB | 1 x Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz (8 cores, 16 logical) with 65536MB
00:00:00 38MB | macOS 10.16.0, Darwin kernel 22.4.0
00:00:00 38MB | soft limit for open files is set at 10238
00:00:00 38MB |
00:00:00 38MB | Installing system handler with mask 255
00:00:00 46MB | [metadata] loading metadata file: /Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/scripts/bin/arnold.mtd
00:00:00 49MB | [color_manager_ocio] default ocio.config found in /Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/scripts/bin/../ocio/configs/arnold/config.ocio
00:00:00 49MB | loading plugins from /Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/scripts/bin/../plugins ...
00:00:00 49MB | cryptomatte.dylib: cryptomatte uses Arnold 7.2.2.1
00:00:00 49MB | cryptomatte.dylib: cryptomatte_filter uses Arnold 7.2.2.1
00:00:00 49MB | cryptomatte.dylib: cryptomatte_manifest_driver uses Arnold 7.2.2.1
00:00:00 49MB | [metadata] loading metadata file: /Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/scripts/bin/../plugins/cryptomatte.mtd
00:00:00 53MB | usd_proc.dylib: usd uses Arnold 7.2.2.1
00:00:00 53MB | [metadata] loading metadata file: /Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/scripts/bin/../plugins/usd_proc.mtd
00:00:00 53MB | htoa_mandelbulb_proc.dylib: mandelbulb uses Arnold 7.2.2.1
00:00:00 53MB | [metadata] loading metadata file: /Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/scripts/bin/../plugins/htoa_mandelbulb_proc.mtd
00:00:00 54MB | alembic_proc.dylib: alembic uses Arnold 7.2.2.1
00:00:00 54MB | [metadata] loading metadata file: /Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/scripts/bin/../plugins/alembic_proc.mtd
00:00:00 54MB | loaded 6 plugins from 4 lib(s) in 0:00.05
00:00:00 54MB | [color_manager_ocio] default ocio.config found in /Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/scripts/bin/../ocio/configs/arnold/config.ocio
00:00:00 55MB | [hick] Start
00:00:00 55MB | [hick] Received: log_verbosity: 3590
00:00:00 55MB | [hick] Received: log_console_enable: 1
00:00:00 55MB | [hick] Received: log_file:
00:00:00 55MB | [hick] Received: log_max_warnings: 5
00:00:00 55MB | [hick] Received: delta_publisher_port: 53711
00:00:00 56MB | [hick] Received: threads: 0
00:00:00 56MB | [hick] Received: assfile: /tmp/houdini_temp/htoa_luke/73863_2cb9c2fd-c5fa-490f-8efc-7c1ffc4bd53b.ass
00:00:00 59MB | [metadata] loading metadata file: /tmp/houdini_temp/htoa_luke/73863_2cb9c2fd-c5fa-490f-8efc-7c1ffc4bd53b.ass
00:00:00 60MB | [ass] loading /tmp/houdini_temp/htoa_luke/73863_2cb9c2fd-c5fa-490f-8efc-7c1ffc4bd53b.ass ...
00:00:00 60MB | loading plugins from /Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/arnold/drivers ...
00:00:00 60MB WARNING | unable to load dynamic library: dlopen(/Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/arnold/drivers/driver_houdini.dylib, 0x0005): Library not loaded: @rpath/libHoudiniUT.dylib
Referenced from: <3FC5E4A1-DA4C-393A-A784-E6850BA72240> /Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/arnold/drivers/driver_houdini.dylib
Reason: tried: '/Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/arnold/drivers/../scripts/bin/libHoudiniUT.dylib' (no such file), '/Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/Libraries/libHoudiniUT.dylib' (no such file), '/Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/arnold/drivers/../scripts/bin/libHoudiniUT.dylib' (no such file), '/Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/Libraries/libHoudiniUT.dylib' (no such file), '/Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/scripts/bin/./libHoudiniUT.dylib' (no such file), '/Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/scripts/bin/./libHoudiniUT.dylib' (no such file), '/Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/scripts/bin/./libHoudiniUT.dylib' (no such file), '/Applications/Houdini/Houdini19.5.6407/Frameworks/Houdini.framework/Versions/Current/Libraries/libHoudiniUT.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Applications/Houdini/Houdini19.5.6407/Frameworks/Houdini.framework/Versions/Current/Libraries/libHoudiniUT.dylib' (no such file), '/usr/local/lib/libHoudiniUT.dylib' (no such file), '/usr/lib/libHoudiniUT.dylib' (no such file, not in dyld cache)
00:00:00 60MB | no plugins loaded
00:00:00 60MB ERROR | [ass] line 34: node "driver_houdini" is not installed
00:00:00 64MB | [ass] read 1711974 bytes, 16 nodes in 0:00.01
00:00:00 64MB WARNING | rendering with watermarks because the skip_license_check option was enabled
00:00:00 112MB ERROR | [aov] output references a non-driver node: /out/arnold1:iprsocket
00:00:00 112MB ERROR | [aov] no valid output statements found: could be a progressive render without a display window
00:00:00 112MB WARNING | failed to launch bucket workers: received abort signal
00:00:28 115MB WARNING | signal caught: SIGTERM -- Termination signal
00:00:00 38MB | [hick] Received: AA: 3 3
00:00:00 38MB | [hick] Batch mode
00:00:00 38MB | log started Tue Aug 1 19:19:12 2023
00:00:00 38MB | running on Lukes-MacBook-Pro, pid=73968
00:00:00 38MB |
00:00:00 47MB | [metadata] loading metadata file: /Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/scripts/bin/arnold.mtd
00:00:00 54MB | [metadata] loading metadata file: /Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/scripts/bin/../plugins/usd_proc.mtd
00:00:00 54MB | htoa_mandelbulb_proc.dylib: mandelbulb uses Arnold 7.2.2.1
00:00:00 54MB | [metadata] loading metadata file: /Users/luke/htoa/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/htoa-6.2.2.1_r0a87540_houdini-19.5.640.py37/scripts/bin/../plugins/htoa_mandelbulb_proc.mtd
00:00:00 54MB | loaded 6 plugins from 4 lib(s) in 0:00.06
00:00:00 56MB | [hick] Start
00:00:00 56MB | [hick] Received: log_verbosity: 3590
00:00:00 56MB | [hick] Received: log_console_enable: 1
00:00:00 56MB | [hick] Received: log_file:
00:00:00 56MB | [hick] Received: log_max_warnings: 5
00:00:00 56MB | [hick] Received: delta_publisher_port: 53711
00:00:00 56MB | [hick] Received: assfile: /tmp/houdini_temp/htoa_luke/73863_ec0c5af2-72f6-40f1-9c2e-657e6dc786f8.ass
00:00:00 59MB | [metadata] loading metadata file: /tmp/houdini_temp/htoa_luke/73863_ec0c5af2-72f6-40f1-9c2e-657e6dc786f8.ass
00:00:00 59MB | [ass] loading /tmp/houdini_temp/htoa_luke/73863_ec0c5af2-72f6-40f1-9c2e-657e6dc786f8.ass ...
00:00:00 63MB | [ass] read 1711799 bytes, 15 nodes in 0:00.00
00:00:00 63MB WARNING | rendering with watermarks because the skip_license_check option was enabled
00:00:02 199MB | [hick] Exit code 0
00:00:02 199MB |
00:00:02 199MB | releasing resources
00:00:02 175MB |
00:00:02 175MB | releasing resources
00:00:02 175MB | unloading 4 plugins
00:00:02 175MB | closing cryptomatte.dylib ...
00:00:02 175MB | closing usd_proc.dylib ...
00:00:02 175MB | closing htoa_mandelbulb_proc.dylib ...
00:00:02 175MB | closing alembic_proc.dylib ...
00:00:02 175MB | unloading plugins done
00:00:03 175MB | Arnold shutdown
00:00:00 38MB | log started Tue Aug 1 19:19:53 2023
00:00:00 38MB | running on Lukes-MacBook-Pro, pid=74068
00:00:00 38MB |
00:00:00 55MB | [hick] Received: threads: 0
00:00:00 55MB | [hick] Received: assfile: /tmp/houdini_temp/htoa_luke/73863_022fcb9d-9b8e-42dd-b55c-413ca85330b4.ass
00:00:00 59MB | [metadata] loading metadata file: /tmp/houdini_temp/htoa_luke/73863_022fcb9d-9b8e-42dd-b55c-413ca85330b4.ass
00:00:00 60MB | [ass] loading /tmp/houdini_temp/htoa_luke/73863_022fcb9d-9b8e-42dd-b55c-413ca85330b4.ass ...
00:00:00 64MB | [ass] read 1711799 bytes, 15 nodes in 0:00.00
00:00:02 199MB |
00:00:02 199MB |
00:00:02 199MB | unloading 4 plugins
00:00:02 199MB | closing cryptomatte.dylib ...
00:00:02 199MB | closing usd_proc.dylib ...
00:00:02 199MB | closing htoa_mandelbulb_proc.dylib ...
00:00:02 199MB | closing alembic_proc.dylib ...
00:00:02 199MB | unloading plugins done
00:00:03 199MB | Arnold shutdown
