Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Arnold Operator - Set Parameter - Finding camera parameter
3 REPLIES 3
am_wilkins
266 Views, 3 Replies
Good day,
A question regarding "overriding" camera DOF settings with arnold operators on a Houdini camera.
I'm trying to use a Set Parameter to turn the DOF "on / off" on different ROP.
I've tried multiple options on the Set Parameter node
dof_enable = 1
dof_enable = on
dof_enable = True
ar_dof_enable = 1
ar_dof_enable = on
ar_dof_enable = True
With and without spaces between the = sign.
I attempted to find the correct parameter name with kick to no avail.
Closest I got was: -info persp_camera
Type          Name                              Default
VECTOR[]      position                          0, 0, 0
VECTOR[]      look_at                           0, 0, -1
VECTOR[]      up                                0, 1, 0
MATRIX[]      matrix                            identity
ENUM          handedness                        right
FLOAT         near_clip                         0.0001
FLOAT         far_clip                          1e+30
VECTOR2[]     screen_window_min                 -1, -1
VECTOR2[]     screen_window_max                 1, 1
FLOAT         shutter_start                     0
FLOAT         shutter_end                       0
ENUM          shutter_type                      box
VECTOR2[]     shutter_curve                     (empty)
ENUM          rolling_shutter                   off
FLOAT         rolling_shutter_duration          0
FLOAT         motion_start                      0
FLOAT         motion_end                        1
FLOAT         exposure                          0
NODE          filtermap                         (null)
FLOAT[]       fov                               60
BOOL          plane_distance                    true
FLOAT[]       focus_distance                    1
BOOL          flat_field_focus                  true
FLOAT[]       aperture_size                     0
INT           aperture_blades                   0
FLOAT         aperture_rotation                 0
FLOAT         aperture_blade_curvature          0
FLOAT         aperture_aspect_ratio             1
RGBA          uv_remap                          0, 0, 0, 0
FLOAT         radial_distortion                 0
VECTOR2[]     lens_tilt_angle                   0, 0
VECTOR2[]     lens_shift                        0, 0
ENUM          radial_distortion_type            cubic
STRING        name
What is the correct 'assignment' to be able to do this?
The collection is simply grabbing the camera:
*Cam_0000_000_renderCameraShape*
I'm calling it: cam
using #cam on the Set Parameter
All the best,
Andrew Wilkins
3 REPLIES 3
Stephen.Blair
in reply to: am_wilkins
The enable flags are not part of Arnold. That's tells HtoA what camera parameters to export (the aperture parameters).
Setting aperture to [0] should disable DOF
For something like this, if I couldn't look at the actual code, I'd export ass files with and without DOF to see what changes.
// Stephen Blair
// Arnold Renderer Support
am_wilkins
in reply to: Stephen.Blair
Hey Stephen,
I exported two ASS files, like you say, with and without DOF.
Doesn't seem like any value is being stored?
I get the following in both exports:
persp_camera
 name /obj/cam1
 near_clip 0.xxx-xxxxxxxx
 far_clip 10000
 rolling_shutter_duration 0.xxx-xxxxxxxx
 motion_end 0
 fov 45.000042
 focus_distance 5
 aperture_blades 5
Thank you!
Andrew
am_wilkins
Hi again,
It appears even though we have expression hooked up to "aperture_size" setting that to 0 works.
aperture_size = 0
Thanks for the help, I will use this so long.
Best,
Andrew
