Arnold not rendering textures in Houdini
will180
Observer Observer
will180
Observer
Observer
So as per the title, the textures are showing in the viewer and if I use Manta or Karma (the built-in Houdini render engines), but not when rendering in out of Arnold.
I imported lots of .glTF from sketchfab.com and they all have the same issue, but not with Manta or Karma.
I also tried all the models from here, and none of them work with Arnold!
https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_for_houdini_tutorials_ah_Learning_Scenes_html
I have posted this on SideFX forum too:
https://www.sidefx.com/forum/topic/93957/?page=1#post-410145
Will
Stephen.Blair
glTF is not supported by Arnold
Those screenshots look like there's no material assigned to geometry. Can you get an Arnold log for a render?
// Stephen Blair
// Arnold Renderer Support
will180
Observer
Observer
"glTF is not supported by Arnold"
Wow, thanks, that's one problem 'solved'.
"Can you get an Arnold log for a render?"
Please see attached.
Thanks again.
Will
Stephen.Blair
I don't see any materials or textures.
There are 2 utility shader nodes, but those are the default shaders created by HtoA.
Normally I would expect to see some standard_surface shaders, and for textures, some image nodes.
00:00:00   229MB         | there are 2 lights and 71 objects:
00:00:00   229MB         |       2 persp_camera
00:00:00   229MB         |       2 point_light
00:00:00   229MB         |       2 utility
00:00:00   229MB         |       2 box_filter
00:00:00   229MB         |       1 gaussian_filter
00:00:00   229MB         |      70 polymesh
00:00:00   229MB         |       2 list_aggregate
00:00:00   229MB         |       3 color_manager_ocio
00:00:00   229MB         |       1 driver_houdini
// Stephen Blair
will180
Observer
Observer
Thanks for looking.
