Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Arnold GPU just creates a grey frame with Arnold 6.1.0.1
7 REPLIES 7
Message 1 of 8
phillips.a.adam
778 Views, 7 Replies
I updated arnold to Htoa 5.5.0.0 to take advantage of the light linking now supported in Arnold GPU. This meant i Had to also change houdini build from 18.0.566 to 18.0.597. Unfortunately GPU rendering has stopped working altogether. Scenes that were working fine now just present a solid grey render buffer in the render view. I looked at the console and it says WARNING [htoa node] [soho] Parameter not found: radius (ar_radius)
Labels (3)
7 REPLIES 7
Message 2 of 8
Can you increase the Arnold log verbosity to Detailed, and post that log?
I don't think that WARNING would explain a solid grey render buffer.
// Stephen Blair
// Arnold Renderer Support
Message 3 of 8
Hi @Stephen Blair, That's kinda what i suspected. Here is a link to the log file:
Download link
https://we.tl/t-CgLgkWR3El
This website does not allow a direct upload of the log file unfortunately
Message 4 of 8
@Adam Phillips
That's a strange log. It never actually renders, and it just re-exports the temporary ass file that was supposed to be rendered.
Does this work on CPU?
What if you Ignore Textures (in the Arnold ROP > Diagnostics) ?
// Stephen Blair
Message 5 of 8
Hi @Stephen Blair, Exactly! it just makes a solid grey render buffer - the 'Generating Image' kind you'd get whilst waiting for first pixel and then stops.
CPU works fine - it's been a lifeline. It's not like the scene is huge either - literally one asset (750k polys) one set of maps and one shader with some very basic shadow/phantom geometry.....that's it. I'm also running an RTX 3090 which should be overkill for a project like this.
The only thing I can think to do is totally uninstalling all aspects of houdini/Arnold when the project is over and starting again.
ignore textures does nothing, same with ignore lights,bump,shaders etc....
Message 6 of 8
Does rendering to MPlay work with GPU? And rendering to disk?
// Stephen Blair
Message 7 of 8
Hi @Stephen Blair , Rendering to disk seems to be working. preview in Mplay doesn't work, there is no response in Mplay window. Judging by my computer fans the same thing is happening.
Message 8 of 8
aaannnnddd just like that it starts to work. I have changed 0 settings - perhaps the render to disk or Mplay attempt jogged something
Technology Administrators
