Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Arnold For Houdini20.0.590
7 REPLIES 7
Message 1 of 8
manikya_
279 Views, 7 Replies
Hello when will htoa for houdini20.0.590 come out
7 REPLIES 7
Message 2 of 8
tom_minor-arnold
in reply to: manikya_
Hey,
The next HtoA release will be built for 20.0.590
In the meantime (assuming you're using the default installation path), you can try changing your houdini.env from
# htoa config start
PATH = "$PATH;C:/Users/<user>/htoa/htoa-6.2.5.1_r539f2c5_houdini-20.0.547/htoa-6.2.5.1_r539f2c5_houdini-${HOUDINI_VERSION}/scripts/bin"
HOUDINI_PATH = "C:/Users/<user>/htoa/htoa-6.2.5.1_r539f2c5_houdini-20.0.547/htoa-6.2.5.1_r539f2c5_houdini-${HOUDINI_VERSION};&"
# htoa config end
 to
# htoa config start
PATH = "$PATH;C:/Users/<user>/htoa/htoa-6.2.5.1_r539f2c5_houdini-20.0.547/htoa-6.2.5.1_r539f2c5_houdini-20.0.547/scripts/bin"
HOUDINI_PATH = "C:/Users/<user>/htoa/htoa-6.2.5.1_r539f2c5_houdini-20.0.547/htoa-6.2.5.1_r539f2c5_houdini-20.0.547;&"
# htoa config end
20.0.547 *should* be binary compatible with 20.0.590, but the ${HOUDINI_VERSION} in PATH/HOUDINI_PATH will break things when using a new version. I've fixed the installer to not do this - but the fix hasn't been released yet, so hopefully this manual workaround helps.
Cheers
// Tom Minor
// Arnold Developer, HtoA
Message 3 of 8
manikya_
Super thanks
Message 4 of 8
manikya_
in reply to: tom_minor-arnold
Message 5 of 8
brianswarthout
I see that HtoA 6.2.5.2 is available and compatible with Houdini 20.0.590 but I'm unable to find the download for MacOS. Am I missing something or is that particualr version simply not available yet?
- Brian
Message 6 of 8
petr_zloty
It looks like the HtoA 6.2.5.2 download links were retracted…
Message 7 of 8
Stephen.Blair
in reply to: petr_zloty
Documentation is published early, actual posting of the download files comes later.
Because doc publishing doesn't always go smoothly, so we have to go early to make sure it is up when the software is released.
// Stephen Blair
// Arnold Renderer Support
Message 8 of 8
tom_minor-arnold
Hey all,
The HtoA 6.2.5.2 builds are correctly uploaded now, sorry for the confusion
Cheers
// Tom Minor
