Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Arnold Debug log, thousands of Null.
3 REPLIES 3
amy_adams_aaa
115 Views, 3 Replies
I have a scene that renders preparation time takes about 15 minutes.
It takes longer than other scenes. Feels not right.
So I turned on 'log to file' and set it to debug mode.
Use vscode and open this log.
seems to log thousands of Null. How to fix it?
3 REPLIES 3
lee_griggs
in reply to: amy_adams_aaa
Is this CPU or GPU? Can you share the full log file? What is in the scene? Anything that could be causing it?
Lee Griggs
Arnold rendering specialist
AUTODESK
amy_adams_aaa
in reply to: lee_griggs
It's CPU render
log attached。
And can you help me out with another problem?
https://forums.autodesk.com/t5/arnold-for-houdini-forum/after-htoa-6-1-0-0-can-not-use-in-cpurenderf...
thiago.ize
I don't see any nulls in the log. That makes me think it's not Arnold printing those out?
Also, this says you're using a version of Arnold from 3 years ago (Arnold core 6.1.0.0). A lot has changed since then. Please try upgrading to see if it fixes whatever issues you're having. In case there's some confusion, there's an arnold core version and an htoa version and those are not the same. Just download the latest htoa (htoa 6.2.3.3 includes Arnold core 7.2.3.3) and you'll be good. https://arnoldrenderer.com/download/
