Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Arnold Crash Houdini Render GPU
3 REPLIES 3
thorleylucas
304 Views, 3 Replies
I am rendering using Arnold, the GPU render gets halfway through and then it crashes even when the primitive number is reduced. I have attached the crash report.
Operating system: Windows 11
Version and Build Number of Houdini: 19.5.569
Crash report from lucas; Mplay Version 19.5.569 [windows-x86_64-cl19.29]
Uptime 438 seconds
Thu May 18 16:18:04 2023
Caught signal 11
Traceback from 20980 ThreadId=0x000030b4
CURRENT THREAD 12468
+0x7ffe8862148c [memcpy] C:\WINDOWS\SYSTEM32\VCRUNTIME140.dll
+0x12fa646d [UT_WorkBuffer::append] C:\PROGRA~1\SIDEEF~1\Houdini 19.5.569\bin\libUT.dll
+0x1400a7b9c C:\PROGRA~1\SIDEEF~1\Houdini 19.5.569\bin\mplay.exe
+0x1400a7fa6 C:\PROGRA~1\SIDEEF~1\Houdini 19.5.569\bin\mplay.exe
+0x1400a650b C:\PROGRA~1\SIDEEF~1\Houdini 19.5.569\bin\mplay.exe
+0x1400b7b9a C:\PROGRA~1\SIDEEF~1\Houdini 19.5.569\bin\mplay.exe
+0x11212e93 [UI_Manager::handleEvent] C:\PROGRA~1\SIDEEF~1\Houdini 19.5.569\bin\libUI.dll
+0x1123a84a [UI_Queue::processNextEvent] C:\PROGRA~1\SIDEEF~1\Houdini 19.5.569\bin\libUI.dll
+0x11238169 [UI_Queue::drain] C:\PROGRA~1\SIDEEF~1\Houdini 19.5.569\bin\libUI.dll
+0x112385ec [UI_Queue::eventLoop] C:\PROGRA~1\SIDEEF~1\Houdini 19.5.569\bin\libUI.dll
+0x10988a07 [AP_Interface::loadWindowGeometry] C:\PROGRA~1\SIDEEF~1\Houdini 19.5.569\bin\libSI.dll
+0x10989676 [myWinMain] C:\PROGRA~1\SIDEEF~1\Houdini 19.5.569\bin\libSI.dll
+0x1400b920e C:\PROGRA~1\SIDEEF~1\Houdini 19.5.569\bin\mplay.exe
+0x14018c13e C:\PROGRA~1\SIDEEF~1\Houdini 19.5.569\bin\mplay.exe
+0x7ffeaf3126ad [BaseThreadInitThunk] C:\WINDOWS\System32\KERNEL32.DLL
+0x7ffeb126a9f8 [RtlUserThreadStart] C:\WINDOWS\SYSTEM32\ntdll.dll
3 REPLIES 3
There's nothing about Arnold or HtoA in that stack trace, so I can't really tell much from it.
If anything, it looks like mplay is crashing.
What's in the Arnold log? In the Arnold ROP, on the Diagnostics tab, increase the verbosity to Info and enable file logging. The Arnold log for a render to mplay will be in that log file.
What happens if you render to disk?
// Stephen Blair
// Arnold Renderer Support
Hi, thank you for your reply, sorry I only noticed just now. I have tried to use a USD Render ROP in stage but after 10 or so frames it crashes.
thorleylucas
in reply to: thorleylucas
For anyone who finds this with the same problem, it took me a while to figure it out, there is a way to use /out not /stage: in the output tab click the small arrow next to output picture and change it to sequence of exr files. This fixes the problem fully. Hope this helps someone! CREDIT: https://youtu.be/K7NDeq9aixk?t=1092
