Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Arnold and steam version of Houdini on macOS compatibility issue
0 REPLIES 0
Message 1 of 1
317 Views, 0 Replies
Ok, so I have asked this related question last time as well.
I was told that Arnold to Houdini works perfectly fine on macOS, and I've tried everything, all the builds available from 17.0 to 18.0 and all corresponding Arnold versions up to 5.2.1. They all don't work displaying same issue. I thought this could be my personal machine issue, so I tried this on my other MacBook Pro and it displays the same issue. I did a bug report to SideFX and they told me to hand it over to Solidangle, and when I asked here nobody could resolve this issue so I think it's not possible to use it.
Command Exit Code: 250
00:00:00 57MB | [hick] Lowered process priority to 19
00:00:00 57MB | [hick] Received: AA: 3 3
00:00:00 57MB | [hick] Received: begin
00:00:00 57MB | [hick] Batch mode
00:00:00 57MB | log started Mon May 18 10:23:08 2020
00:00:00 57MB | Arnold 6.0.2.1 [088e32fd] darwin clang-5.0.2 oiio-2.1.4 osl-1.11.0 vdb-4.0.0 clm-1.1.2.132 rlm-12.4.2 2020/03/06 10:20:27
00:00:00 57MB | running on CHANGYOONs-MacBook-Pro.local, pid=6658
00:00:00 57MB | 1 x Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz (6 cores, 12 logical) with 32768MB
00:00:00 57MB | macOS 10.15.4 "Catalina", Darwin kernel 19.4.0
00:00:00 57MB | soft limit for open files raised from 10238 to 10238
00:00:00 57MB |
00:00:00 57MB | [hick] Start
00:00:00 57MB | [hick] Received: log_verbosity: 7942
00:00:00 57MB | [hick] Received: log_console_enable: 1
00:00:00 66MB WARNING | unable to load dynamic library: dlopen(/Users/chang/htoa/htoa-5.1.1_r126b954_houdini-18.0.391/htoa-5.1.1_r126b954_houdini-18.0.391/arnold/drivers/driver_houdini.dylib, 5): Library not loaded: @rpath/libHoudiniUT.dylib
Referenced from: /Users/chang/htoa/htoa-5.1.1_r126b954_houdini-18.0.391/htoa-5.1.1_r126b954_houdini-18.0.391/arnold/drivers/driver_houdini.dylib
Reason: image not found
00:00:00 66MB ERROR | [ass] line 28: node "driver_houdini" is not installed
00:00:00 66MB WARNING | rendering with watermarks because the skip_license_check option was enabled
00:00:00 77MB ERROR | [aov] output references a non-driver node: /out/arnold1:ip
00:00:00 77MB ERROR | [aov] no valid output statements found
00:00:00 77MB WARNING | failed to launch bucket workers: received abort signal
My issue is whenever I hit render on Arnold ROP it displays this, aborting the entire render.
It seems like driver_houdini.dylib dynamic library file that is included with Arnold for Mac can not be installed properly in this case.
Some of you told me to try Arnold 5.2.1, yes I tried with it and it is still the same.
Now I can't think that this is just the compatibility issue with Arnold and steam version of Houdini on macOS.
If you can recommend any methods to resolve this issue, that would be greatly appreciated.
If you are planning to buy Steam version of Houdini, don't buy it. I wasted $249 worth of money which they don't work together.
Tags (1)
Labels (1)
0 REPLIES 0
