Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Arnold 6 with Houdini18 Solaris
10 REPLIES 10
Message 1 of 11
hailu_wang
2745 Views, 10 Replies
Is there a render output node with HtoA5.0.0 under Solaris of Houdini?
I mean when I finished my shading, , lighting under Solaris, I need to render it out. But currently I cannot find a render output node of Arnold, what I only can do is just swith this render engine in hydra view. How can I render out my picture?
Tags (2)
Labels (2)
10 REPLIES 10
Message 2 of 11
in reply to: hailu_wang
The basic workflow
add rendergeometrysettings
add rendersettings, but unfortunately arnold tab is missing
add usdrender_rop choose Arnold
Message 3 of 11
hailu_wang
Thank u, rachid.
Yes, the missing Arnold render setting tab is a big problem.
Did u export a image successfully by using the "usdrender_rop" node? I followed your step and try to export my render. But there is nothing under my output fold.
Message 4 of 11
Any news on this?
Still empty "render settings" node in Htoa 5.0.2 so the Hydra delegade is pretty much usless atm.
Would be great to get an official answer as to why its empty.
Message 5 of 11
Sorry i didn't see your question.
unfortunately, it is impossible to render anything to disc, since Render Setting for arnold is empty.
why is empty ? ask the team!
Message 6 of 11
julian.hodgson
We have the ticket https://trac.solidangle.com/htoa/ticket/1356 to add this.
Message 7 of 11
schwungsau
still not working in lastest update 😞
Message 8 of 11
schwungsau
after more digging, Solaris is not ready for any renderer. Solaris currently is useful for layout scene and generate USD files.
Arnold operators is way to go, right now, its kinda mini solaris itself.
Message 9 of 11
in reply to: schwungsau
Ready for Renderman,
5955-pxar.jpgReady for Redshift at least beta
5956-redshift.jpgbut nothing for Arnold !Operatores is arnold specific, not USD !
Message 10 of 11
No PXR_PLUGINPATH_NAME variable on fresh Install (HtoA 5.1.1)
From the doc: https://docs.arnoldrenderer.com/display/A5AFHUG/HtoA+5.1.1
#1396 Install hydra render delegate to dso/usd_plugins
but still not working even when adding PXR_PLUGINPATH_NAME to point to Hydra
PXR_PLUGINPATH_NAME = C:/Users/rachid/htoa/htoa-5.1.1_r126b954_houdini-18.0.391/htoa-5.1.1_r126b954_houdini-18.0.391/dso/usd_plugins
no probleme with others renderers (Renderman, Redshift, 3Delight) ,only Arnold !
why is that ?
Message 11 of 11
With the newest version somehow there is only a global headlight. Everylight inserted in LOPs does not update the global headlight mode. And it crashes most of the time when I switch between the render engines. Does anybody have the same problem?
Technology Administrators
