Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
alembic procedural does use not velocity for motion blur
6 REPLIES 6
schwungsau
1403 Views, 6 Replies
alembic procedural does use not velocity for motion blur, instead, Arnold tries to create its motionblur, which it mess because of changing point count. if write ass files it works, it take v attr for motionblur.
if i unpack and load into Houdini the alembic Arnold take v for motionblur, but it takes much more to the first pixel. that's why i wanna use almebic procedurals.
is it a bug or feature?
Labels (2)
6 REPLIES 6
The alembic procedural should use velocity data if it is in the archive. How are you exporting the data? Are you exporting with the velocity data in the alembic?
Ashley Handscomb Retallack
Arnold Support Specialist
Arnold Documentation | Arnold Downloads
schwungsau
in reply to: schwungsau
default alembic SOP, the alemebic file has v attr if reload it in houndini and unpack it...
does it have be renamed to "velocity" ?
julian.hodgson
See an example file from our test suite: alembic_vel.zip
schwungsau
of coursce i am exporting velocity data. renderman and octane gets it. even gaffer and arnold works, but htoa has issues to use velocity in alembic files.
schwungsau
in reply to: julian.hodgson
it works in gaffer but not in Houdini.
ikefalas
Hi, how did you get to make Renderman use velocity attributes from alembic? I ‘ve stored velocity attributes as 3float color and although I can import and use them with pxrprimvar nodes when shading, I cannot figure out how to use them to motion blur my changing topology water geometry
