Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
After HtoA 6.1.0.0, can not use in CPUrenderfarm
9 REPLIES 9
Message 1 of 10
amy_adams_aaa
293 Views, 9 Replies
Seems HtoA 6.1.0.0 update note said:
  • The driver type must be set to DCH.
After this version, I can't use this version on CPU render farms
And CPU render farm workers do not have GPU or graph cards.
I got an error with deadline 10.
2023-09-11 10:27:29:  Scheduler Thread - Render Thread 0 threw a major error:
2023-09-11 10:27:29:  >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
2023-09-11 10:27:29:  Exception Details
2023-09-11 10:27:29:  RenderPluginException -- Error: Renderer returned non-zero error code, -1073740791. Check the log for more information.
2023-09-11 10:27:29:     at Deadline.Plugins.PluginWrapper.RenderTasks(Task task, String& outMessage, AbortLevel& abortLevel)
2023-09-11 10:27:29:  RenderPluginException.Cause: JobError (2)
2023-09-11 10:27:29:  RenderPluginException.Level: Major (1)
2023-09-11 10:27:29:  RenderPluginException.HasSlaveLog: True
2023-09-11 10:27:29:  RenderPluginException.SlaveLogFileName: C:\ProgramData\Thinkbox\Deadline10\logs\deadlineslave_renderthread_0-A08-32core-32G-0000.log
2023-09-11 10:27:29:  Exception.TargetSite: Deadline.Slaves.Messaging.PluginResponseMemento d(Deadline.Net.DeadlineMessage, System.Threading.CancellationToken)
2023-09-11 10:27:29:  Exception.Data: ( )
2023-09-11 10:27:29:  Exception.Source: deadline
2023-09-11 10:27:29:  Exception.HResult: -2146233088
2023-09-11 10:27:29:    Exception.StackTrace:
2023-09-11 10:27:29:     at Deadline.Plugins.SandboxedPlugin.d(DeadlineMessage bgq, CancellationToken bgr)
2023-09-11 10:27:29:     at Deadline.Plugins.SandboxedPlugin.RenderTask(Task task, CancellationToken cancellationToken)
2023-09-11 10:27:29:     at Deadline.Slaves.SlaveRenderThread.c(TaskLogWriter ajv, CancellationToken ajw)
2023-09-11 10:27:29:  <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
It works fine with HtoA 6.0.2.2, with no graphic card.
and HtoA 6.1.0.0 works fine with a graphic card installed on it.
So, what should I do?
9 REPLIES 9
Message 2 of 10
I also tried manually using Hython, not work.
tried editing device.py and ai_device.py to disable GPU,  not work again.
Message 3 of 10
That's for downloading the driver from NVidia. That will have nothing to do with a render.
// Stephen Blair
// Arnold Renderer Support
Message 4 of 10
You should check the logs from the render node.
// Stephen Blair
Message 5 of 10
Only got this error exit code:
Houdini and Arnold shut down accidentally.
And I have tried, Disable HTOA, using mantra to render, and it works.
So this is not related to the Houdini version.
Message 6 of 10
I think after HtoA 6.1.0.0 Added some GPU detection while loading the HTOA plugin, couldn't detect it, so crashed and exited.
Message 7 of 10
please help
Message 8 of 10
thiago.ize
in reply to: amy_adams_aaa
If you can enable arnold logs (maybe the latest htoa will do a better job outputting the log file) it would say if it exited out because of GPU.
Are you maybe by accident trying to render on the GPU? Or maybe you have the optix denoiser (uses gpu) enabled? If you make a new scene from scratch that contains nothing, doesn't have a denoiser, is set to CPU rendering, and submit that to the farm, does that work?
Message 9 of 10
amy_adams_aaa
in reply to: thiago.ize
No, it crashed before the render started. crashed while loading the Arnold plugin. So don't have any debug logs.
Message 10 of 10
thiago.ize
