Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Why the z channel rendering will be jagged
4 REPLIES 4
å__æµ__é__
5532 Views, 4 Replies
Tags (1)
Labels (1)
4 REPLIES 4
zenop
in reply to: å__æµ__é__
Because it doesn't make sense to interpolate between values for the zdepth. If it would be filtered, you'd get an interpolation of depth values from both your foreground object and your background object around the edges. This is generally unwanted, so it defaults to the "closest" filter. You can change this in the AOV settings if you'd want to for a specific case.
å__æµ__é__
in reply to: zenop
Thank you Zeno Pelgrims, would also like to ask you a question now the film process are using this zigzag Z channel? I'm just curious about whether the workflow is correct, because my colleague has always stressed that the need for anti-aliasing Z channel is correct, I hope to get an answer. Thank you again!
zenop
I've personally never used a filtered depth aov. I have seen it, but the cases are rare. Use the "closest" filter unless you know what you're doing 🙂
å__æµ__é__
in reply to: zenop
thanks!!!!!
