Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Why isn't the alpha working in Arnold for Cinema 4D v5?
15 REPLIES 15
Message 1 of 16
demodunk
759 Views, 15 Replies
Tags (1)
Labels (1)
15 REPLIES 15
Message 2 of 16
lee_griggs
in reply to: demodunk
Can you please provide more information? Which file format are you using? PNG?
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 16
demodunk
I've tried both png, tiff and psd and nothing seems to work.
I've attached a simple scene file.
alpha-test.zip
Message 4 of 16
Seems like a bug. It works if you move the base material after the polygon selection tag.
Message 5 of 16
demodunk
Hmmm.. doesn't work for me. I get white, scaled cirkels where the red i supposed to be.
Message 6 of 16
I'm not sure it's Arnold's fault, I've got the same result with the standard renderer.
Message 7 of 16
demodunk
Working now after I removed the actual alpha from the black and white pic.
Really strange...
Message 8 of 16
demodunk
Thank's for taking a look at my file.
You know if there is any way to file a bug report regarding the stacking order?
Message 9 of 16
This forum post stands as a bugreport. I'll try to fix it for the next release.
Message 10 of 16
demodunk
Aha, ok, thank's!
Message 11 of 16
demodunk
So, just found another bug...
I changed the bump height on the base material to 0,05 and the alpha disappeared.
Changed it back to 0.1 that I had before and still the alpha is gone. Had to press re-do a couple of times to get it back.
This seems like a pretty buggy software.
Message 12 of 16
demodunk
Happens when I change other parameters too.
Turns out I needed to close the IPR window and open it again.
Message 13 of 16
That's strange, I'll try to reproduce it.
Also note, that instead of material stacking, you can use the layer shader, which gives you more control and kinda the recommended way with Arnold.
alpha-test-v2.zip
Message 14 of 16
demodunk
Thank's I tried that but I never got that to work either.
Message 15 of 16
Your original scene should work now with this wip build, please give it a go if you have some time:
https://safeshare.solidangle.com/index.php/s/ljxlVTXMM3eaGLz
password: c4dtoawip
I'm also working on some other issues regarding the native decal workflow reported earlier.
Message 16 of 16
The fix is now available in 2.3.1.3.
