Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
why is working with quixel so complicated
3 REPLIES 3
gomeslindsay
229 Views, 3 Replies
is there someone that can make it easy for me to understand quixel texturing in arnold
it never seems to be as sharp as the preview images and it gets confusing with the displacement height , bounds pad, scaler zero how do you set them to be perfect enough to give it that sharp realistic look of any object in my case i used a rock and it was rounded and the edges and not sharp
Tags (1)
Labels (1)
3 REPLIES 3
There is a lot of post production on those previews. I know they sharpen the renders to make it look super detailed. To get something close you need a mix of displacement, normal map and bump map.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
where would I input the bump map in the nodes ?
You are in Cinema4D so I am no 100% sure of how it works. In 3ds Max you need to connect your bump map to a Bump2D node which then connects to the Arnold Standard Surface Normal slot.
https://docs.arnoldrenderer.com/display/A5AFCUG/Bump2d
And you can combine both the bump and the normal map, by connecting your normal map to a Normal node. The Output of the Normal node connects to the Normal slot of the Bump2D.
here is the setup in 3ds Max
Ciro Cardoso
Technology Administrators
