Why is the material distorted when i animate the mesh?
dim.hak
Observer Observer
dim.hak
Observer
Observer
If I animate the mesh, the material gets distorted. Why is this happening?
For example:
peter_horvath
If you have a procedural texture (like noise) which you'd like to stick to the object you need to add a Pin Material Tag (former Stick Texture Tag) to the mesh, or export a reference object and use the Pref space in the shader, as described here: https://docs.arnoldrenderer.com/display/A5AFCUG/Export+Parameters#ExportParameters-Referenceobject
Otherwise it could be maybe an animation/simulation setting to prevent the UVs swimming, not sure.
// Peter Horvath
// C4DtoA developer
dim.hak
Observer
Observer
Thank you very much! It's work
