Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Why does this object with transmission block out the image texture from the object beneath? Pic attached.
2 REPLIES 2
sjonesWRUZH
153 Views, 2 Replies
Why does this glass lens block the image texture on the compass dial beneath the lens? I've been trying lots of things and cant get the texture to show through the object with transmission. 8343-screen-shot-2020-10-06-at-84959-pm.png
Tags (1)
Labels (1)
2 REPLIES 2
schwungsau
in reply to: sjonesWRUZH
check your normals, it may inverted normals
Can you send me your scene to take a look? Can you check the same setup with different simple objects to see if it's something wrong with the geometry?
