Which shader node controls the Slope and Altitude in a landscape or mountain?
diego6S3FN
Message 1 of 13
diego6S3FN
Hello, I would like to know the best approach to texturize mountains and landscapes.
Replies (12)
Message 2 of 13
maxtarpini
you may look into a 'snow' shader for altitude and then triplanar mapping for easy texturing.
Message 3 of 13
diego6S3FN
Hi, Sorry but I can't see any "snow" shader on C4dtoA.
Please which node can detect the inclinations. Like "Terrain Mask" on C4d.
Message 4 of 13
Slava_91
or get mask from aiUtillity normal Y to V uv coordinate ramp
Message 5 of 13
diego6S3FN
HI, Sorry again but I can't find that aiUtillity it really looks like I'm on the wrong forum here. I'm C4dtoA user. I'm looking for a way to create a kind of snow shader.
Message 6 of 13
lee_griggs
More information about the Utility shader can be found here.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 7 of 13
diego6S3FN
Thank you for your help, I really do not understand how I can use Utility node to distribute snow depending on slope on a terrain.
Message 8 of 13
diego6S3FN
I see that the "Snow" shader it is only for Maya, I'm looking for a "slope" node solution on Cinema4D to Arnold plugin.
thanks.
Message 9 of 13
Slava_91
Message 10 of 13
ashley.handscomb.retallack
@Diego Bonati You could use a combination of curvature shader and a ramp_float to mix two surface shaders, then you have control over the slope and the level of mix.
Ashley Handscomb Retallack
Senior Software Engineer (Arnold)
Arnold Documentation | Arnold Downloads
Message 11 of 13
diego6S3FN
Hi, thank you for your help, I tried your set up on Cinema4D but it don't seems to work, The Utility node it is on Shade mode Flat and Color mode Normal like you.
Message 12 of 13
diego6S3FN
@Ashley Handscomb Retallack
Hi, well that it is not a real terrain texturing solution since it is based on curvature and not in degrees slope.
Please take a look to the attached screenshot you will see that with real slope C4d solution you have blue color also in the 0º normal surfaces.
I think the good solution is the one made by @Viacheslav Sych but for some reason it not seems to work on C4DtoA.
Thank you for you help and screenshot.
Message 13 of 13
diego6S3FN
Hello, I finally found a solution that works on C4dtoA.
I liked the idea of mixing two different shaders one for rock and one for snow but then the Utility Slope is not bump sensitive and much detail is lost.
Here you can control the degrees slope with Ramp float node.
Thank you all for your help.
