Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Where to plug the bump map in the standerd surface shader in Arnold 4.6.5?
1 REPLY 1
no188328
83 Views, 1 Reply
I've searched online and the only answers I found was for Maya. I have a material texture that includes a normal map and a bump map. How to connect them both to my shader? It's easy and straight forward for the normal map, Geometry>normal. But I can't find the right input for the bump map.
1 REPLY 1
peter_horvath
in reply to: no188328
Bump and normal_map both go to the Geometry > Normal attribute. If you want to connect both shaders, you can chain them through their Normal attribute.
// Peter Horvath
// C4DtoA developer
