Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
WARNING| options: could not read INT parameter "render_device"
6 REPLIES 6
826 Views, 6 Replies
Hi
Can someone help me what this warning is about?
Tags (3)
Labels (3)
6 REPLIES 6
Stephen.Blair
older version reading file saved by a newer version
// Stephen Blair
// Arnold Renderer Support
in reply to: Stephen.Blair
Sorry i don*t understand what you mean.
What is a reading file? How can i fix it?
thiago.ize
Your version of Arnold is older than the version used to generate the scene you're reading in. Upgrade your Arnold if you want that warning to go away. Otherwise, it likely should be safe to ignore this warning.
Stephen.Blair
You are using an older version of C4DtoA, and loading a scene that was saved while using a newer version of C4DtoA.
// Stephen Blair
Cristina_C
hi! Both my versions of Arnold and cinema are updated. I Just created a new file to avoid problems, and I still get the message. I think is slowing down my IPR window a lot
This warning should be fixed in C4DtoA 3.0.3. It should be harmless, the plugin checks this parameter to detect if a gpu or cpu render is running, but this parameter does not exist on Mac, that's why the warning.
Technology Administrators
