Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Volumetric lighting via image file on selected polygons
3 REPLIES 3
simonEPZ3S
330 Views, 3 Replies
Hi All,
I am just starting to learn C4DtoA so hopefully this is not a dumb question...
I have a cube (converted to a polygon) and want one side to be an emissive material (PNG image) and the rest to be a metal texture. I also need the emissive polygon to show in the atmosphere volume I have in the scene. I have tried two ways...
If I use the PNG in the emissive slot of the texture it does not show up in the atmosphere which is what I need. I am able to use polygon selection tags to have the PNG assigned to one poly and a metal texture to the remaining polys though.
If I use a mesh light, the PNG "shows" in the atmosphere but I can seem to find a way to use a polygon selection with a mesh light. This means I can't have the other polygons set to the metal material.
Am I missing something or do I essentially need 2 objects (one for the metal parts and one for the image part)?
Labels (2)
3 REPLIES 3
lee_griggs
in reply to: simonEPZ3S
Emission does not work with Atmosphere Volume. Use a Mesh light on a separate object instead.
Lee Griggs
Arnold rendering specialist
AUTODESK
simonEPZ3S
OK, got it working now. Thanks for the info Lee.
Yeah, the mesh light tag currently does not work with polygon selections. That's an improvement I want to add in a future release.
